Bassman2003
We all have blind spots and too much to do at times. Hopefully you can have a 2nd chance!
Day two. taking the three sounds noted above..
Absolutely. Its a skinny tin box with a muscle engine.Sounds like a race car! But that side door sounds like a junk yard car!![]()
The fuss is.. first run version did not sound good.What was all the fuss about? Sounds fine.
I was worried about ruining the microphones. (which I still dont understand!)
Im still not clear which mics types dont get 'clipped'
Thank you for this, it is helpful.It all depends on the materials used in building the mic, but it comes down to sensitivity and SPL handling. You just want to make sure that the mic you choose has plenty of headroom for the sound source you’re trying to record.
Condenser mics are active. Phantom power activates the capsule along with an impedance conversion circuit in the mic chassis. They often have lower SPL handling, and due to the active circuitry have hotter output signals. Dynamic mics generate their own signals without external power, often having higher SPL handling, and have lower output signals because they’re passive.
Every microphone spec sheet should have an SPL rating, as well as sensitivity, signal to noise ratio, and self-noise rating. I say “should”, as I find one or two of these missing from spec sheets on occasion.
As for clipping and distortion, that can happen when the capsule is pushed to its limits, or it can happen within the circuitry (either in the mic, or in the preamp). Damage really only comes from pushing a mic past its handling limits for a prolonged period (except for ribbon mics, which are much more fragile, but that’s an entirely different conversation).
It’s all about picking the right tool for the job, and knowing which tools are better in which situations.
Alex can weigh in on this but I see mics as very durable outside of physical impacts like dropping and being submerged in water etc... Sound (environment) alone is not a concern to me. You might damage your recording, but not your mic.
Thanks Alex. Two questions:
Which type, brand or level of condensers need to be handled with care?
Can you define handling with care compared to normal use and storage in a case?
Durability is not part of that realm, generally..
