Tomas Riuka
http://www.sounddevices.com/download/pix-firmware/
Did anyone see this?
FREE updates lets you record 12bit prores 4444 from f3!
Merry christmas
Merry christmas
I think you need rgb paid update, because free update lets yu have slog,but not rgb output. Pix records via single 3g sdi cable, says so in the manual, just read it. Will go to the office in one hour and test everything. As this happens via single cable, it's not possible to get 1080 60p,but i for free, i don't mind prores 4444![]()
AFAIK, F3 does 60p only through dual link output.
Just tested, setting f3 to 3g rgb444 output works like a charm with pix240 via single cable. Pix detects input signal and shows it's 10 bit rgb. Did a quick test, didn't notice any substancial visible changes recording prores hq 422 or 4444, i guess that would come up when keying![]()
well, i can't measure it for surebut according to sony you can output RGB 4:4:4 1080 23.98/ 25/ 29.97PsF signal is available over an HD-SDI dual-link or 3G H-SDI output so if you have RGB (paid slog) update, you should be getting true RGB 444 via single 3G SDI output and record it with pix. As far as i remember, previously, setting camera to 3G 444 ouput, made Pix recorder go blank and don't see any image, now it works.
Grug, pix can't handle 1080p 60frames, i think they said it's impossible due to hardware.
Great! So this just made the F3 4:4:4 option app. 3k cheaper (comparing to the previous cheapest option Gemini)?
Seems like, yesit's just Gemini does 444 uncompressed and 1080 60p. Imho 4444 prores is enough , cause if you need THAT much, it's always easier to take another camera like Alexa with raw recorder.
I think the question is whether this means we can get 1080 60p at 422, considering the Pix240 is now a 3G device, not a single link 1.5 device.
