Graeme_Nattress
Red Team
Not quite yet....
Graeme
Graeme
Jarred Land said:Ive never seen a colorist use anything other than a HD CRT reference for color. There is always a projector in the room for sure for shiits and giggles, but decisions are never made off of it. And im talking Technicolor, Toybox, etc. they bragged about Sin City being timed with a DLP monitor but the actual operator was using a crt.
Thomas Mathai said:If they are timing for a theatrical release, they should be looking at a projector, and that projector should be calibrated to emulate a film print.
That doesn't mean that they don't have a CRT sitting in there with them.
The director and DP will be making their decisions based on the digital projection.
Even if a colorist used a CRT, the look has to be approved by someone else on the final medium, be it film or video.
im.thatoneguy said:Depends. I've seen client rooms with HD CRTs for client monitoring. I've seen blown theaters for DI with the op using a CRT. You will always need to use a CRT for work because you don't want to project your interface to the client. They don't need to see you shift the hue, and you need to see the interface. But when it comes to the client anything beyond a monitor is gravy, even the interface monitor is almost always as accurate as the projector, usually more.
Jarred Land said:Ha ha true.. but for color accuracy and matching the CRT is used.. its kinda like previewing SD material on a standard television, which is always in SD edit suites.. the argument of watching it on the end result is fine, but your not going to see professionals color timing on a Toshiba 27" tele.
I think we both may be more right though.. DLP projectors get better every 6 months it is becoming more and more and more accurate with dare i say real blacks and a decent contrast ratio.
