Hi guys and girls,
We are new to editing, but we are, for the most part, doing pretty well with figuring out CS4. We are using an HPX170. We shot a chase scene in 720/24p. Whe imported the footage into CS4 and it plays great in the Source window. The problem; if you simply edit out a short piece and drop it into the time line, when viewing it in the program monitor on the right, the video looks notchy. We have tried everything we can think of. If you continue on an render out and produce a movie through CS4 Media Encoder, the results are the same, notchy video. Even if you do NO editing and just render out and encode the raw footage the results are the same.
We are setting up the project and the scence, by the book, so to speak.
We have also done some test chase scenses since using different formats; standard def and also 720/60p with the same results. It is like something is happening to the video when you drop it into the time line.
Machine specs:
PC with XP Professional with service pack 3
7200 rpm 150 gig hard drive with very little on it
2.8 gig processor/core two duo
4 gigs of ram
We have had the same results on another machine with virtually the same specs and also on an HP laptop.
Thanks in advance for the help
Wayne Mann
Machine specs:
4 gigs of ram
Wayne Mann
