First, let me say that I’ve been scouring the internet for methods of controlling D90’s video mode, especially the ISO levels, for some time now. There are a few suggestions dispersed here and there, with Kholi’s method producing the best results.
I think I’ve found a new method at least worth exploring - it seems to be a pretty consistent way to estimate/control ISO level, though I’ve only played around with it for a few hours. Very interested to see what other users think.
The Video
To get right to it, I created a video of a dark scene, in which I methodically increase the ISO level, using a “gray screen” method. No lighting changes in the video, only the exposure - some combination of ISO and shutter speed. I’ll get into more detail later on why I think this method offers some control over ISO.
D90 ISO Control Test
In the video, no lighting changes and the aperture remains constant at f1.8 (using the Nikkor 50mm f1.8). As I step up the ISO, I attempt to keep the shutter speed to a minimum, and you can watch the difference as the video goes from Estimated ISO 200 to Estimated ISO 3200. It's not the best test in terms of scene lighting - when I get more time I might do another test with more interesting lighting.
The Lead-In
If you’ve never tried the Auto ISO feature, it basically works by automatically increasing / reducing the ISO based on the amount of light available. It allows you to specify the minimum shutter speed that is acceptable before increasing the ISO. So let’s say you set that to 1/30 - if the scene is too dark and the camera would like to drop below 1/30, instead it will increase the ISO automatically. The reverse holds true if the scene is overexposed.
Doesn’t this sound a lot like how the video mode seems to work? It automatically adjusts shutter and ISO depending on available light, and probably maintains some “bottom” shutter speed level.
The Technique
Essentially, use the Automatic ISO Sensitivity to make an educated guess about what ISO level you’re locking in. The idea is that when you have this turned on and you have made a good guess about the min. shutter speed the movie mode uses, you can get a good estimate of what ISO you’re at.
This I think is where the community can help in determining what that bottom shutter speed really is. (It should be measurable from video right? (Given an object moving across the frame at a constant and known speed?) Knowing that bottom value might make it easier to mimic the movie mode ISO levels in Auto ISO Sensitivity mode.
One more consideration in trying to control shutter speed is that at any given ISO in auto sensitivity mode, there are a range of shutter speeds. Once the shutter speed gets too low, the camera boosts ISO. So if you slowly darken your exposure “gray screen” until just before the point the camera jumps to a higher ISO, you should be able to get the slowest shutter. Do the reverse to get a faster shutter speed.
Conclusion
This is a very presumptuous post - I don’t really know if the camera is doing what I hope it’s doing. I might be completely wrong about all this, so take it with a grain of noise, er salt. But when I’ve played around with it in low lighting, I did get nice clean images using this method. The best thing about this method is that you gain some feeling of control because you can see what numbers you “locked in” at even while you’re shooting video. Hopefully, this gives you more control over what the camera does. And it’s actually a very easy technique.
Let me know what you think!
The Video
The Lead-In
The Technique
- In the menu, turn on Auto ISO Sensitivity. Set min. shutter speed to either 1/15 or 1/30 (more on this later).
- (EDIT) Set exposure compensation +/- to -0.3 or lower (i.e., -0.7).
- In Aperture Priority mode (other modes might work too?), set your desired aperture. Alternatively, use a manual aperture lens.
- Looking through the viewfinder or at the little screen on top, point the camera at the right amount of light to get your desired ISO. Obviously, point at brighter exposures to get a lower ISO. You can also use a laptop LCD with a dark gray background and adjust the brightness level to get a consistent ISO.
- (optional) Keep pointing camera at darker areas until it jumps to the next higher ISO, then back off slightly to get back to your desired ISO - this would hopefully keep the shutter speed low.
- Once pointed at the desired ISO, quickly push AE/L (Lock) and then immediately push Live View. You can almost push them simultaneously. (This step has some room for further experimentation)
- Now you should have a locked shutter and ISO. If your scene is too dark, then either add lighting or accept that you’ll have to use a higher ISO.
Conclusion
