Not sure if my workflow is 100% correct but so far it has worked for quite a few shoots, in to out.
There's really no such thing as a 100% correct workflow. It is dependent on the user.
I'd say yours is pretty common though as far as t2i/7D/5D footage goes.
A good Compressor tip I got from user BenB is to make a droplet on your desktop for your transcoding.
I have heard about this shortcut before. Can you explain a little bit more or perhaps PM me to walk me through the setup?. Thanks so much
In the compressor settings window do the following:
- Select the setting you want to use for your droplet
- Click the "Save Selection as Droplet" button (middle of the 3 buttons at the top left)
- Type in the name for your droplet, where you want it, and the destination, click "Save"
That's all there is to it. To use it, just drag your files on top of the droplet, compressor will launch and convert your footage.
3/ Open files and convert to prores - As my system can run prores 4444, Ive pretty much decided regardless of any actual visible difference any commercial work goes this way. Or prores 4:2:2 HQ (These files will be auto backed up every few days).
