Phil Seastrand
Excellent! Thanks again for your detailed reporting so I could easily find the flaws.
Those additional files are not being copied from the SD card by PHOTOfunStudio, they are being generated by PHOTOfunStudio. Unfortunately I don't know what the specifications are in order to create them. Additionally, it was never my intention to replace all the functionality of PHOTOfunStudio, just the import features.Hi Phil, some additional data is in these files which is relevant for PhotoFunStudio.
Without these files PhotoFunStudio does not recognize the m2ts file and won't play it. I suspect the .tmb file contains a thumbnail. Without this file no thumbnail is presented, after copying this file a thumbnail is visible.
As ralph789 is saying, PhotoFunStudio is good enough for watching the raw video as came out of the camera.
For the time being, I won't be editing and I mainly need a mediamanager for visually presenting the collection I have. For images, ACDSee is my favorite but that doesn't support AVCHD. So I think for Panasonic user PhotoFunStudio is the best free SW. (Or do you know other SW that visually present AVCHD collections, not being a specialized editor?)
So is it possible for you to extend your program with copying these files as well?
I find your SW very easy to use and reliable. Separation of photos and video is also what I want. For this reason I very appreciate your effort and the good result. The extension which also copies the other files, will make it perfect for me.
However, to solve your presentation problems there are several options, but the one I suggest is to make Windows Media Player support M2TS files. Then all of Windows should do what you want, including thumbnails in Windows Explorer. To make this work, follow the instructions here http://forums.techarena.in/windows-software/1180526.htm#post4414970 to update the registry to support M2TS file types.
Other people may have better suggestions, but this should at least get you started.
You are right.Phil's program is about importing video and pictures neatly.
The previous poster was concerned about browsing a video collection, which windows 7 does reasonably well natively.
Any better programs for browsing/managing a video collection?
Don't believe VLC does this - just a straight player.
Thanks for the feedback. Let me look into if I can easily find that information and include it as an option for the file name. I'll get back to you when I have an answer.Phil, great program, one issue im having though is that if i shoot 60i/24p, 60p, and 30p in the same day i have to manually go through and determine the framerate so i can IVTC the 60i, or change the fps of the 60p. Can you have this info append to the end of the filename?
Hi, is there any chance for a version for mac? Thanks.
