PC Windows Workflow? Help
Blackout
Well my GH1 finally arrived!
Previously I have been testing with a friends on his mac, but I have a high end windows quad core i7 box and I am having a nightmare figuring out proper workflow. I can't import with the included photofun software, it crashes when it tries to aquire from the camera. I pulled in the native files from the private stream directory, but even vlc is not playing them right.. it's a flickering stroby mess...
I have Premiere pro cs4 & sony vegas... and I can't get either of them to render out the 1080 24p properly.
Been looking around here and can't find a proper PC workflow thread, so if you could point me in the right direction I'd appreciate it cause my head is hurting at this point.
Some questions:
Do I HAVE to purchase voltiacHD or something similar to get the footage off the camera and edit and create a blu-ray and a standard dvd version?
Premiere will see the footage using avchd 1080i widescreen 29.97 fps, but when I render it out to a regular mpeg2 dvd codec or blu-ray codec I am seeing ucky problems. Tried 10 different tests to see if premiere could remove pulldown or just render out the 1080 60i as is but I'm having no luck.
I don't seem to be having this issue on some canon 7d files.. they play natively.... scratching my head with the gh1 at this point.
Thanks for any starting pointers.
- Michael
I don't understand why you have a problem. My system is Vista-64 running on an i7/6GB RAM with Vegas Movie Studio Platinum. I simply copy the .mts files from my GH1 SD card onto my C: drive, import them into the Vegas Media folder, and drag/drop them on the timeline. Nary a glitch in any of this, and it's very fast.
If you are having a problem doing this there must be some step you are missing or some detail you haven't mentioned. There are a few things to note:
1. i7's have 8 CPU's, not 4. Vegas defaults to 4 max for rendering, so to use 8 you need a tweak
2. Vegas has a glitch rendering HD quality on 64-bit OS's. If you have a 64-bit version of Windows you need a tweak.
4. Vegas MS uses DVD Architect 4.5 to create DVDs. This version will NOT create Blu-Ray disks (BDs.) To create BDs you need Vegas Pro, which uses DVD Architect 5.
Which version of Vegas are you using? In Vegas Pro 9 you can just import the mts files, but if you're working with 1080 files it won't remove pulldown. Premiere won't do pulldown on GH1 footage either.
I've heard mixed things about Voltaic, I tried it out and did not like the compression.
Neoscene seems to be the way to go if you're using GH1 1080 footage on a PC (that's what I'm doing - the new i7 box is on the way! can't wait as I've been editing on a Pentium D!)
Neoscene is fast, simple, nearly lossless and easy to work with, it will make your life much easier. It just works. The cineform avis will work perfectly in either Vegas or Premiere.
There aren't many solutions on the PC side for GH1 pulldown removal - life is easier on the Mac in this respect. They have more options. Go for Neoscene, it's definitely worth the $100. If you have not already, you can download a trial version that works for 7 days I believe, this way you can give it a test run.
I think I have an older version of vegas. Will try Neoscene and see how the trial is. I also think some of the video codecs on my vista ultimate might be screwed up. Time to install win 7. Don't know if that will fix anything.
i'm running a puny 3.5ghz core duo compared to you gusy and don't have any issues. however, win7 plays raw gh1 files like a dream. upgrade if you can. also, don't expect to edit the 1080p footage in premiere. you can't remove pulldown. use neo scene.
oh, and my comp is even punier...if that's a word.
2.4 ghz Core2Duo Win Vista Home Premium/NVidia 8400GS video card with an "upgraded" MSI motherboard...not sure why i bought it. anyway, it's an HP i bought at Best Buy in 2006 for $599 on sale....yeah, in short, it sucks. or does it?
I also have the cheapo Vegas Movie Studio 9 Platinum ProPack ....BUT...i have never experienced problems editing from the GH1 for the month that i've had it. Had the Canon XH-A1 before the GH1...no problems.
External Harddrives help a great deal for computers as slow (on paper) as mine.
I have vegas 8. That must be the issue. Tried Neoscene trial and it looks pretty good... so one is forced to spend another $130 to do anything with the footage I guess? How do they expect this camera to be aimed at normal consumers I have no idea. I consider myself pretty computer agile and this gave me a headache. Thanks for the help though!
I just find the fact that Panasonic doesn't offer a simple tool to do this on either a PC or Mac is strange.
This is really a problem much more on the PC side than the Mac side, and there's a good chance that most people using GH1s for serious work are also working on Macs. It's the PC side that's really left to fend for themselves...I don't know what we'd do if it weren't for Neoscene.
To be fair though, these problems don't apply to all GH1 footage - the 720 stuff (maybe they figure most people will be using that) doesn't need pulldown removal.
What version of Windows are you running?
If you are using Windows 7, you don't need any special software to import AVCHD movies from the GH1 Sd card; windows 7 will automatically offer to import the .mts files as soon as you connect the sd card to your computer. You can choose the directory it will import into. It will only import the .mts files, which is not a problem for most software. You can also play the .mts files using Windows Media Player, which I have found is way way better than anything else I tried including VLC.
Alternately, you can import the videos using PhotoFunStudio HD (the panasonic software) using "acquire". This software will import the .mts files and three other related files that it needs to play back or edit the movies.
I will be doing a clean install of win 7 in a a few weeks. Waiting for some new big hard drives to come from newegg.
But still, how do you edit the native mts files? I CAN get those into premiere but the pulldwon is still there and they don't render out correctly to dvd or to bluray burning applications. They look funky.
i'll just say it again. you can't edit 1080p in premiere and expect it to remove pulldown because it doesn't. you need to convert using neo scene or voltaic hd or cut 720p 60p files by dropping them on a 24p timeline.
Ok... so here is another question... once I transorm all my footage and remove pulldown with neoscene, what settings do I use to edit within premiere CS4?
I only see avchd 1080p 23.97 I don't see any regular .avi settings for the newly conformed files.
I don't use CS4 that much, but when I do and use cineform files I just make a custom project at 24p that is 1920x1080p. Everything works just fine.
