Peter J. DeCrescenzo
http://www.vimeo.com/4334428
Motorcycle test. Feel like I'm seeing some jello, although it's a heck of a lot better than what the D90 would look like under those conditions.
Yes, you'd expect to see at least some CMOS image sensor motion artifacts, in this case "vertical jello", as the motorcycle abruptly bounces up & down. In the video, the utility poles' apparent height stretches & squeezes as the cam's CMOS chip scans the scene from top to bottom while the bike bounces. :shocked:
Some experimentation on the part of the camera operator may yield an appropriate solution to minimize this effect. It seems clear that "hard mounting" a CMOS cam to a motorcycle isn't likely to produce visually appealing results compared to using a CCD-based cam.
I don't know if cushioning a CMOS cam (such as with foam rubber), or using a lightweight steadicam-type arm, would improve the results or not. Finding a good solution could be fun for those who appreciate a challenge, motocycles and video cameras.
- Peter
www.peterdv.com
