Okay, I'm stationed in the press conference, waiting for it to start. I've got Luis Caffesse and Stephen Mick on my right, and Mikko Wilson and Jake Carpenter on my left... press conference starts in five minutes.
Jan,
Just curious...What's the technical reason behind that? Why can AVCCAM have the capability of 1080/60p VFR and not AVC-Intra? Thanks!
Jan,
I'm guessing it's because 10-bit 4:2:2 is a lot more data to process than 8-bit 4:2:0.
The RAW signal from the sensor digitizes to an uncompressed 422 stream that then gets compressed, so I believe it's actually it's the opposite. Someone correct me if I'm wrong.
The AVC version of the camera is still going to be working with an 8-bit image as opposed to the P2 version's 10-bit...i.e. the AF100 only does 8-bit out the HD-SDI indicating that whatever image it ends up with internally is 8-bit, whereas in the HPX370 and HPX 250 that use 10-bit AVC-I, the HD-SDI out is 10-bit. So what it boils down to is 10-bit is a lot more data than 8-bit, and is probably what limits the 10-bit cameras from doing 1080 60p.
Good point. I wonder if that is enough to offset the heavy compression of AVCHD tho.
Yeah, see that's tough...I love shooting overcrank, but how much? Forcing a choice is brutal.
Currently the "heavy comprression" of AVCHD handles the 60 Frames just fine in the AF100. And I wouldn't call it heayvy, I would call it elegant and efficient. Go look at the scenes in the Verse before dying. The reason that the 250 doesn't do 60 in 1080 is the the bits at 100Mbs becomes too much to handle. It is not whether it is 10 bits ot 80 bits in the codec, it is because signal is just too big too handle in the AVC-Intra. Easier when the Mbs is smaller.
Live coverage from the Panasonic Press Conference at NAB 2011...EDIT: Video of the Press Conference is now online: http://www.dvxuser.com/V6/showthread.php?245594-Panasonic-Press-ConferenceAdditional Live Feeds:Coverage here at DVXuser.comNews: http://www.dvxuser.com/V6/content.php?9-nab-show-2011 Discussion: http://www.dvxuser.com/V6/forumdisplay.php?223-NAB-2011Mikko WilsonLIVE Photo Gallery: http://nab.mikkowilson.com/2011/http://www.dvxuser.com/V6/oto Galle.../ Twitter: http://www.twitter.com/mikkowilsonTwitter: http://www.twitter.com/mikkowilson Jake CarpenterBlog: http://jakecarpenter.posterous.com/LIVE Photo Gallery: http://jakecarpenter.com/gallery2/main.php?g2_itemId=31Twitter: http://twitter.com/jakecarpenter - Mikko
