joe12south
Let's not confuse external recording with external monitoring. Some devices do both, but many, many users take advantage of the benefits of a monitor, like SmallHD, while recording internally.
Yeah it depends. When the camera first launches the 10bit will be limited to 150mbps. 400mbps is only coming later in the year. ProRes422 HQ 4k 24p is 880mbps and the internal all-I format is 400mbps. That is a pretty significant amount.
Think of an all-I format like saving a jpg image. The different levels of ProRes are like saving a jpg image at 65%, 75% or 85% quality. These are rough figures just to get a perspective of whats going on. 400mbps would be more like a jpg at 50% quality which is ok but not great. Video using this type of compression tends to show the compression artifacts and mosquito noise a lot more since it dances around and moves around edges and fine details. The lower the data rate the more artifacts you will see in the image. Not the same kind of artifacts as an IPB macro frame but they are still artifacts just like a badly compressed jpg image.
Remember on the GH4 it is highly recommended not to use the HD 200mbps all-I mode because it just doesn't look as good as the IPB modes. 200mbps should be plenty for HD but alas it was not on the GH4. So far Panasonic doesn't exactly have a good track record when it comes to all-I formats. I hope they have improved on them but past history tells us they will not be spectacular. The 72mbps HD mode on the GH3 was kind of ugly as well.
It will no longer be an absolute must to use an external recorder but if you are working on a serious productions and something you want to be proud of you want to still consider it.
A few other things to keep in mind.
1. While the GH5 may have some scopes they are tiny on a tiny 3.2" LCD. An external monitor gives you much larger scopes that are easier to see fine details. The scopes also have to be turned on via the camera menu and switched in the same menu which can take more time vs a simple external monitor menu system.
2. False color is an extremely useful tool for setting exposure with log. The GH5 does not have false color.
3. The GH5 LCD is small and still doesn't show the large critical resolution to nail focus at a good 7" monitor. Professionals were using external monitors long before they used them to record external material.
4. ProRes is a tried and true format used by a lot of people. Hard to really go wrong having ProRes files in the Mac world. There is a good reason why BMD, Varicam and ARRI use ProRes as a recording format in their cameras outside of raw.
5. An external recorder like the Flame is a 10bit FRC display which means it will be easier to judge 10bit colors on the monitor. Shooting with just the GH5 will get you close but it will never be a 100% perfect judge of what you are shooting.
6. An external recorder can be used not directly attached to the camera. For example on a stand with a long HDMI cable run. I find this extremely useful at times when I can sit in front of the camera and bring the monitor with me to see how the lighting and setup looks.
7. External is future proof and can move around to other cameras. If you decide you don't like the GH5 and want to move to another camera you can still record the same format and have the same monitoring tools you are used to.
You bring up a good point on monitoring the video with a 10-bit display. I can't remember where I heard this, but one of the Panny marketing guys said the new rear display has RGBW elements and the rear monitor is now an LCD monitor instead of an OLED. I wonder if this monitor can do accurate HDR representation since the summer firmware is adding this capability?
This is a technical question, not a marketing question, as I understand there may be marketing differentiation concerns here as well. But if the GH5 can record 4K sustained at 60p, and even that doesn't top out it's hardware bitrate (400mbps coming in summer, providing even more data bandwidth)...
Then why is it capped at 180fps 1080p? 4K is 4x the pixels of 1080, so given that it can currently handle infinitely sustained 4k 60p with headroom (since we'll have a higher bitrate codec coming), wouldn't it stand to reason that 1080p 240fps would be about the same data throughput as 4k 60p?
I will definitely be supporting Hyper Log Gamma curve with a LUT when it's released, on top of Cine-D and V-Log L. Hopefully it fills the 10bit bucket like Joe said, while using all the dynamic range of the camera's sensor (see how much more you can pull out of a GH4 stills image compared to video and you'll understand what I mean).
I also agree with the upcoming 400Mbit codecs probably being AVC-Ultra. Makes sense that they'd want to get it right and have the SD card speeds to cope with it, to sell through vertical integration. Should be great if that is the case, combined with HLG....
Cheers,
Paul![]()
I'm hopeful - but skeptical - about AVC-Ultra. Panasonic is better than any other manufacturer about letting "pro" features slide down into consumer products, but my guess is that they will want to leave AVC-Ultra as a differentiator.
Also, it's good to remember that the reason an all-i codec needs so much bandwidth is not purely PQ, but rather edit-friendliness. It's less taxing on the editing CPU to not have to reconstruct frames, but it's not necessarily visually better. (Oft times the opposite is true.)
I mention this because it's easy to fall into the simplistic thinking that all-i codecs are always better, as that's how they are usually marketed. A long-gop codec is more capture friendly, more storage friendly, modern CPU's are more likely to be able to decode reasonably fast, and you always have the option to transcode (just what you need) to a native edit-friendly format. NLE's like FCPX make it brain-dead simple to quickly, invisibly used transcoded and proxy footage, which yields the best of both worlds.
Granted, there are some special scenarios where you really do "need" either the quality of a bandwidth heavy codec or the speed of an all-i codec, and in those cases a ProRes recorder does the job nicely. Those scenarios diminish with each camera generation, though. For example, my GH3 used to require a recorder to pull high quality 1080P keys...but now I can easily do so from GH4 4K footage. I expect i'll be able to pull clean 4K keys from the GH5.
I agree, SmallHD charges way too much for its monitors especially given the monitor in the atomos is true 10-bit HDR capable and 1500 nits, so alone I don't see why anyone would buy the 702 etc, the recording capability is a bonus. Well I know SmallHD got bought out by a larger company so much of the benefit for the consumer went away with that acquisition and they're still operating on pricing from years ago when there weren't many decent affordable options.
Of course but the biggest issue people have with recording externally is the extra piece of gear. If one is going to use a monitor anyway then there is really no extra effort in recording externally. Currently the Flame is the only 10bit 1920x1080 1500 nit brightness panel on the market so even if one just wanted a good monitor I would choose that over a SmallHD any day.
I agree that SmallHD's pricing is tough to swallow...but the physical quality of their gear is on a whole other level than that of Atomos. My SmallHD 7" OLED has been beat to hell and never hiccuped. (And I mean smashed so hard to be reassembled.) I had an assistant drop a Ninja from waist height and it died.
If it was AVC-Ultra I would be ok with that but it isn't. It is their regular AVC-HD encoder since it needs to encode the other AVC formats. Besides that doesn't explain why the 200mbps all-I format was so bad on the GH4 when AVC-Intra was already around and looked good at 100mbps. If it is in fact AVC-Ultra which is why we have to wait until later this year then that would be really good.
AVC-Ultra 4k up to 30p just so happens to be 400mbps. Hmmmmmm...
