Mitch Gross
Will Bill's presentation be publicly available after CG?
Don't know.
Canon C200 leaked images just cockblocked the new Panny. Now we just have to see what Sony pulls out.
A lot will depend on how crippled C200 internal recording will be. A 305 Mbps with 10-bit C-Log - good enough for the SD cards - and Dual Pixel AF will please many. But they go 8-bit internal ...
Not sure how I feel about the rumors of the new cam having a "new sensor" instead of the one in Varicam 35/LT/Pure.
You used to post a lot on the official BM forum (not sure if you still do; I'm not active there anymore) and should know better than anyone that the UM/UMP has problems.
All of the cams might be comparing paper specs, and the BM might turn out to be better, but first you have to get a good one off the conveyor belt.
If true it should mean a less expensive camera. I can't see Panasonic under cutting it's own Varicam LT camera by using the same sensor in this new lower cost camera.
Nor do I think it's simply going to be a GH5 sensor in a ~DVX200 body, per se.
Why not?
I don't think it's MFT. I sure hope not. I don't know anything about the cameras specs.
Sony uses the same sensor in the FS5, FS7, F5 and F55. They just limit the ability in them based on the model. Not sure about processing if that's different in each. Sure keeps the cost down unless they have larger future plans for a new sensor then that makes sense as well. The end of all this guessing is almost over. Looking forward to interviewing Mitch at Cine Gear for Newsshooter.
