P2 Offload speed
Barry_Green
Moderator
It's commonly reported that P2 offloads to hard disks at either about "a gig a minute" or "2 gigs per minute." On an older powerbook G4, it seems to take about a minute per gig, or 16 minutes for a 16GB card. On a modern Windows laptop with the PCMCIA slot, it takes around 30 seconds per gigabyte, or 2 gigs per minute, or about 8:15 on my laptop to offload a 16GB card.
But -- does it need to be so? Could it be faster?
I got the idea from watching a 64GB P2 card be offloaded on a Mac Pro, using a PCD35 PCI-Express slot reader. It took barely over 10 minutes to offload a full 64GB card to a SATA RAID.
... and my Lenovo supports SATA, and two drives internally ...
So, yeah - I partitioned off a hunk of my internal C: drive into a new partition, and installed a second hard disk in the UltraBay. Using Windows' disk manager, I striped those two together and offloaded a chock-full 16GB card.
The result? A full 16GB card offloaded in 4:55. That's over 3GB per minute!
So then, I thought - hey, I've got an ExpressCard eSATA adapter and an external eSATA drive, so let's add that in the mix. So I re-did the RAID as a three-drive RAID. It helped, but only a little; it took 4:45 to offload the 16GB card. That's about 3.4GB/minute, or around 60 megabytes per second, which is closing in on the theoretical maximum of 80 megabytes per second that a P2 card is supposed to be able to support.
Now, if I had a 64GB card, I'm pretty sure that this three-drive RAID would probably hit the 800mbps promised speed, since that's what I've seen it do before.
Is this practical? No, not really - I don't know that I would want to be offloading my footage to RAID zero! But, it does go to show that the slower offload speeds aren't the card's fault, it can clearly be much faster. And this also shows why you can offload to two separate drives (such as an internal SATA and external USB) at full speed without sacrificing any performance... and that's probably a better way to make use of the card's speed.
In any case, it was pretty cool to configure a three-drive SATA RAID on a laptop... heh. If I'm ever asked to perform the world's fastest portable P2 offload, I think we now know how to make it happen. :thumbsup:
Very interesting - good info.
btw - thanks for your input to my question yesterday Barry - most helpful.
I'm gonna get the 64 gig card!
Here's my thinking:
With the 64 gig card (I plan on shooting mostly 720pn) I'll have nearly 3hrs of field recording which should easily cover me for most projects that I'll be doing.
When/if I need more space, I'll still have another slot in the camera free and maybe by then my second 64 gig card will have come down in price a little.
I'll be offloading to a MacPro and will be using a 4 drive eSATA Sonnet (port multiplier) configuration so the 800mbps transfer rate is a nice bonus!
dmc
David,
Initially just Firewire (which I realize won't afford me the speed increase described above.) If the offload times become to unwieldy, I may look at having to use one of the PCI slots and an adapter.
Not sure yet.
dmc
That's why I am asking, but the options for a MacPro running 10.5.x are very extensive at all.
Tom K. here has gerry rigged one reader and PCI E board, but there is nothing off the shelf available, and OS X has issues with alot of it.
Hmm... thanks for the info David.
I thought for sure that I had seen an appropriate PCI card on the OWC site. I guess a little more research is in order.
I appreciate your feedback.
dmc
