P2 Log Pro
n8ture
I see there's a new verion of P2 Log out called P2 Log Pro.
Looks like it has some nice new features...
P2 Viewer: Instantly view Panasonic P2 MXF video clips on your Mac. Great for checking transferred clips before clearing P2 cards.
Edit Clips: Change User Clip Names, Auto-Fill text, add descriptions, Delete unwanted Clips.
Save: Updates P2 Volume.
Create: New P2 Volumes--use with Avid & other NLEs.*
Find: Find, Replace, Sort.
Search: Across entire folders of P2 Volumes for specific Clips.*
Select: Mark or select just the clips you want to output.
Merge: Drag & Drop Clips between open P2 Volumes.*
Export: Create FCP XML files including converted QT Clips.
Repair MXF: P2 Clip Repair Wizard builds valid P2 Volumes.*
Print: Choose from 2 print styles to keep a paper index to your clips.*
SD Cards: Load and program HVX200 SD metadata.
P2 Compatible: P2 cards, P2 Store, FireStore.
PAL Compatible: Plays/converts 720P 25&50 Clips.
* P2 Log Pro version only
I got this info from them, too.
The ability to repair P2 volumes from the mxf files is the one that make me a customer once more...
Gunleik
David S. said:
I can't tell if this permits the user to set in and out points before export.
Good question. Here's another, would P2 Log Pro allow you to add keywords to your clips so if you shoot a bunch of shots for general use and then go hunting for the one of (insert keyword here) it's easier to find??
You got it bud, that's kinda the whole point. But, for more deluxe search/archive functions go for HDLog Silver or Gold. Staying with P2 format you're stuck with the camera's template of fields (not even a 'log note' field).
