Owners: ISO reports, please.
Kholi
Section Moderator
5D, my threshold was 640 ISO. I find it bordering dangerous on the MKii...
7D - 640 - 1/50 - Zeiss Contax 180/2.8 @ F4 - Tiffen ND 8 + 2
I forgot I had the ISO up to 640 ( was doing a deep focus shot with the 180 ) and ended up capturing this. I'm quite surprised at how clean it is. I'm going to try some 1250 stuff, but question is if anyone's had a chance to skim through the ISO's to see which increments are cleaner?
I assumed it's the same as the 5D but maybe I'm wrong.
(Sorry, slightly soft focused. Sunlight killed my eyes~)
Yeah. But it's not the lcds fault. It's the sun in my eyes. I can focus off of a 2.5 inch ikan sd LCD fine. This is tons better. Just wasn't in a good spot.
gh1 still wins the LCD battle. Articulating can't be beat. I'll suffer lower resolution for somehing I can actually use without transforming into some sort of gangly bird what's neck can articulate like the arm of a gorilla pod.
My 2.5" ikan needs a new battery pack. Should be good in a few days.
You know it, papa. Plus nds
In neutral.
Quite pleasing. I played footage back on my Sammy 46" and the contrast and saturation
added by the screen made it look quite freaking nice.
I just tested ISO's at 100, 200, 400, 500, 800, 1600 and 3200. From my initial tests I found that there wasn't a huge increase in noise from 500 to 800 - it was quite comparable. You definitely start seeing noticeable noise at 1600 to 3200. I'll post results soon.
I also tested Canon's High ISO noise reduction options (tested @ 800, 1600 and 3200) and found they did nothing to improve the situation. Perhaps it only takes effect for stills usage.
Yeah, I don't think that noise reduction works for video. That's probably a good thing though.
Sounds like 800 may be fairly reliable, though. Sweet!
ISO testing results:
http://www.barrycheong.com/blog/?p=231
Will definitely be testing again with a higher range of contrast and textures. Since I wanted to maintain the same stop on the lens the lighting shifts a little from test to test. I'll try to get my hands on some ND's next time instead of netting and scriming stuff down. Base was T/2.8 1/2 @ 100 ISO.
No hardcore testing here - but from the little bit of shooting I've done so far, I pretty much zeroed in on 800-1000 as my limit as to what I thought was 'acceptable.'
Of course, 'acceptable' is a subject thing... but, for what it's worth it seems like we're all hitting on the same range.
considering we're limited to f2.8 - on the wide end atleast - with most lenses... i kinda need ~ ISO 2000-2500 to be usable... i don't mind a bit of grain. like nice film grain. as long as there's no crazy banding or colours or lines that show up etc...
on the 5D i was using 1250 at f2 and that's what i needed for my most extreme lowlight work...
and suprisingly it all works out to be the equivilant to T500 with T1.3 super speeds :) which is kinda good to learn to set your limit at that visualy.
maybe i'll be forced to use a 35mm f1.4 and nothing wider for night shots. then i can get away with ISO 640.
Jennings. Use it before you assumeit. LoL
it's QUITE fast, dude. 2.8 @ 640 or 800 ISO is sweet indoors.
kholi. 2.8 at 800 would only be just enough for an interior shoot in most of the houses i know. and that's in a nice house with lamps and brown walls. of course i'm talking about natural lighting. maybe suplimenting it with a chinese lantern here and there.
but i can shoot those locations with proper lighting and my HDcam/adapter kit already.
i just DP'd a 5d shoot with my f2 nikon prime kit. we lit an entire street set with 2 gennies. 1x 2k, 2x redheads, 1x 600w fraynel. it was insane. half the interior scenes were shot with just a 20w CFL in a chinese lantern and a super dimmed 4 bank kino as a fill.
i wanna keep doing that. and be able to shoot at night with no lights in the midle of the city or in a bar and go dogma with a lowprofile multi cam shoot and wireless mics. isn't that the dream? :)
i just DP'd a 5d shoot with my f2 nikon prime kit. we lit an entire street set with 2 gennies. 1x 2k, 2x redheads, 1x 600w fraynel. it was insane. half the interior scenes were shot with just a 20w CLF in a chinese lantern and a super dimmed 4 bank kino as a fill.
I still think you can, man. I'll find out for ya, though. Everything I shoot's either with 150w HMI's or China Balls. If I couldnt' do that I would be disappointed but so far, with the 7D, I can.
In neutral.
Fantastic. My camera should be here by noon today!
I did some extensive side by side iso tests between the 5d and 7d yesterday. Been working 18 hour days and not able to post video up.
I will say this.
The 7d and 5d are nearly identical at low isos.
The 5d holds up better when you get into the 1250 ISO and up range, in terms of total noise (assuming you have calibrated or at least are shooting with a neutral picture style).
The 7d does worse with underexposure but also appears to need less light if all settings between the 5d and 7d are the same (possibly because the sensor is smaller?).
Also - the banding I saw with my 5d every so often when I shot high ISO (eg 5000 ISO) doesn't appear on the 7d. The 7d has more total noise at these ISO settings, but I have found them to be more "natural" looking. Obviously this is an opinion. The 7d's noise appears to dance where as the 5d's can be fairly stationary - hopefully that makes sense.
On top of that. With all settings the same, the color rendition out of the 7d appears to be slightly superior, but again that is a critical educated look and nothing explicitly scientific yet.
I am being as critical and cautious of this camera as I was when I got my 5d and my GH1 (sold the GH1 because the codec gave me headaches).
This is an INCREDIBLE camera. Possibly my favorite camera I have ever used (This includes all the $100,000+ big boys).
It probably has nothing to do with the size of the sensor. (Why would it?) The differences between the image of the 7D and that of the 5D seem to suggest differences in sensor design. Different design explains the different brightness levels, noise pattern, color rendition, latitute, etc.
I realize that I might be stating the obvious, but I don't think that we should attribute the differences to anything else without good reason.
This jibes with other reports. In other words, good news: The 7D doesn't have so much of a "fixed pattern noise" problem. And it's not just an opinion; we can scientifically determine it just by shooting and analyzing footage.
Could this also be just an opinion?
Awesome. :D
