GH4 Olympus M.Zuiko Digital 75 mm f/1.8 ED , sharpest and fastest m4/3rd telephoto lens
joe1946
The resolution test of the Olympus 1.8/75 was based on RAW files from the Olympus E-PL1 camera. In the case of that body the highest results achieved by the best fixed-focus lenses are about 80 lpmm (the record value of 82.6 lpmm was reached by the Voigtlander 0.95/25). The decency level is set near 42 lpmm.
The performance in the frame centre can be only called brilliant. Already at the maximum relative aperture the lens goes to a very high level of over 64 lpmm. Stopping down the aperture only improves the situation further – near f/4.0 you are on a practically record level as the lens gets to 82 lpmm there. Taking into account measurement errors, the images generated by the Olympus are as sensationally sharp like those of the Voigtlander 0.95/25 or the Panaleica 1.4/25.
http://www.lenstip.com/351.4-Lens_r..._Digital_75_mm_f_1.8_ED_Image_resolution.html
I just received the lens from B&H and here is an HDR shot of it on my GH4 with Sony VG900 with 28-70mm FE OSS and Sony A7r with Sony Zeiss Sonnar T* FE 55mm f/1.8 ZA :
sharpest and fastest? try the 42.5 f/1.2 :)
[h=2]Panasonic Leica DG Nocticron 42.5 mm f/1.2 Asph. P.O.I.S. Image resolution :[/h]4007_roz.jpg
The resolution test of the Leica DG Nocticron 42.5 mm f/1.2 Asph. P.O.I.S. was based on RAW files from the Olympus E-PL1. In the case of that body the highest results, reached by the best fixed focus lenses, amount to about 80 lpmm (and the record value of 82.6 lpmm belongs to the Voigtlander 0.95/25, with the Olympus 1.8/75 not far behind).The decency level is set near 44-45 lpmm.
http://www.lenstip.com/394.4-Lens_r...mm_f_1.2_Asph._P.O.I.S._Image_resolution.html
[h=2]Olympus M.Zuiko Digital 75 mm f/1.8 ED Image resolution :[/h]3712_roz.jpg
Going by the actual F-stops both of these lenses are extremely good bt f/2.0. Impressive stuff. ( now try comparing handheld sharpness to tripod mounted sharpness, because it's hard to be a human tripod )
