OHMYGAWD! Uncompressed BlackMagic 10bit recorder for $345
Yup - saw this a few minutes ago... it also looks like it covers all flavours of HD signal over HD-SDI & HDMI (which is also 1.4) so maybe the first out of the block for Sony's TC over HDMI?
The studio version (with LCD) looks very nice too.
I have always loved Blackmagic Design. Best bang for buck in the industry. This steals a little bit of thunder from Convergent Design Wow! This definitely is on my list for 2011. But uncompressed? Gonna have to get used to transcoding to Cineform overnight.
Hmm, this is an awesome announcement. But, I wonder the cost differences when compared to other products when you consider the kind of space needed to hold 422 10-bit Uncompressed...even a minute of it. The copying speed is certainly attractive though, wow.
Anybody know how many GBs 1 minute of 10-bit 422 1920x1080 UNC is? I just exported a 5 second clip and based on my math it's almost 8GB a minute. Granted, I would likely trans-code to something like Prores later since there's no way I could possibly edit these files (not on my system).
128GB SATA III SSD would run you about $300 bucks or so. So for maybe $700 you can get 16 minutes of recording before it would require a dump. Am I getting anything wrong here?
There are cheaper SSDs out there, at the same GB space and reliability. FOr this application, unlike RED and recording to 4K Uncompressed(ish), it's okay to roll with something a little more cost effective. It's like HDMI cables, you just need to make sure they're proper spec, the rest is just data. Spending 100.00 on an HDMI cable is silly, go to Monoprice, same stuff, five bucks.
But, you're also right that uncompressed footage is going to eat your SSD's alive. This is exactly why I feel like it isn't as much a hard push for the shooter versus archiving and delivering masters. SSD price is going to come down in the next few years, it's already begun to plummet over the last four months. Tape can't get much cheaper and it's old hat, the upfront costs are drastic in comparison. Unless someone wants to correct me, I think this is good info for conversation.
A 128GB SSD should be able to fit an uncompressed SD or HD show. I'd have to calculate but that's my initial thought.
Awesome...but...what if we want to record lightly compressed footage to make post easier? Will there be an option to record to a different codec possibly? Or uncompressed only all the time? Still very cool.
+1
Compression is your friend (most of the time), especially in sub 10,000 cameras where uncompressed usually shows a lot more noise. (The F3 could greatly benifit from this though). Throw in an intraframe 4:2:2 codec somewhere between 100 and 200 mb/s and I will be happy.
Perhaps I was using the wrong codec then? Quicktime has a specific 10-bit Uncompressed 422 codec you can export something to, and 5 seconds of that was almost 700MB. That's about 7.9GB for a minute of that codec. BM's site doesn't seem to tell you any charts for what space would give you how much recording. If it's locked at 10-bit 422 Unc then they should be able to simply make up a chart without an issue. There's no other variables except how many GBs you plug into the thing.
Also no info on battery life...would love to see that. :)
525 NTSC uncompressed;
8 bit @ 720 x 486 @ 29.97fps = 20 MB per/sec, or 70 GB per/hr.
10 bit @ 720 x 486 @ 29.97fps = 27 MB per/sec, or 94 GB per/hr.
625 PAL uncompressed;
8 bit @ 720 x 576 @ 25fps = 20 MB per/sec, or 70 GB per/hr.
10 bit @ 720 x 576 @ 25fps = 26 MB per/sec, or 93 GB per/hr.
720p HDTV uncompressed;
8 bit @ 1280 x 720 @ 59.94field = 105 MB per/sec, or 370 GB per/hr.
10 bit @ 1280 x 720 @ 59.94field = 140 MB per/sec, or 494 GB per/hr.
1080i and 1080p HDTV uncompressed;
8 bit @ 1920 x 1080 @ 24fps = 95 MB per/sec, or 334 GB per/hr.
10 bit @ 1920 x 1080 @ 24fps = 127 MB per/sec, or 445 GB per/hr.
8 bit @ 1920 x 1080 @ 25fps = 99 MB per/sec, or 348 GB per/hr.
10 bit @ 1920 x 1080 @ 25fps = 132 MB per/sec, or 463 GB per/hr.
8 bit @ 1920 x 1080 @ 29.97fps = 119 MB per/sec, or 417 GB per/hr.
10 bit @ 1920 x 1080 @ 29.97fps = 158 MB per/sec, or 556 GB per/hr.
1080i and 1080p HDTV RGB (4:4:4) uncompressed;
10 bit @ 1280 x 720p @ 60fps = 211 MB per/sec, or 742 GB per/hr.
10 bit @ 1920 x 1080 @ 24PsF = 190 MB per/sec, or 667 GB per/hr.
10 bit @ 1920 x 1080 @ 50i = 198 MB per/sec, or 695 GB per/hr.
10 bit @ 1920 x 1080 @ 60i = 237 MB per/sec, or 834 GB per/hr.
OK so I was right about the space needed. Looks like most of us will stick to 15min record times or so on 128GB drives. That makes this product a tougher sell for me, but I guess if you slowly invest in a couple SSDs over time it's not so bad. I don't have to dump everything right away I can fill my first 128GB then just stick it in a safe case and move onto #2.
The other thing to note is whether or not it'll start recording (if you're using HD-SDI) when you hit record on your camera or AF100 (like I have). It's always nice to have the little card inside giving me a backup as well.
Anybody know of any SATAIII SSD's for a lower price than I was talking about above? Newegg.com has 128GB's for around $300 or so...
If you look at P2 prices and recording times, the SSDs feel like a bargain.
A 600GB Intel SSD comes for € 939,-
That gives you almost one and a half hour of recording time of uncompressed 10 bit full HD 24p.
What more can you ask for?
Frank
Question: what affordable camera can output 10bit into this, sub 6k dollar level?
I think the new 1/3" Panasonic's might be. The HPX250 will be AVC-Intra (10bit) and have an HD-SDI. It's AVCHD kid brother the AC160 will also have an HD-SDI out as well. Aside from recording format/media, they're basically the same camera. I would see no reason why either wouldn't be 10bit out (though that is purely specualtion). Even if it's 8bit, the AC160 with an SRP of $5,500 (probably street priced at around $4,700) plus this could still be very attractive.
Frank
Absolutely. Not complaining I just want to get a handle on what would be needed to actually make this thing field ready. This has 12v power like the KiPro does unlike the Nano which is much lower and can be power via a Swit battery. I'm sure Barry will bring that up sooner or later as to why he wouldn't get one. :P Either way if the battery is sufficient for a decent time, it might not matter as much.
Anybody else realize that at the cost of the recorder itself, if you can't afford a super expensive battery pack to run your camera and this thing at 12v, you could just buy a second recorder and have it charged ready to go? Can't do that with a KiPro :) At $350 this thing has some funny advantages...
The ex1/ex1r, that's about it. I don't want to be a negative nancy, but the SNR you're going to get from the 1/3rd chips in the new panny's is going to dither the signal right back down to around 8 usable bits, maybe even less. We'll have to wait on actual numbers!
