OHMYGAWD! Uncompressed BlackMagic 10bit recorder for $345
Yup - saw this a few minutes ago... it also looks like it covers all flavours of HD signal over HD-SDI & HDMI (which is also 1.4) so maybe the first out of the block for Sony's TC over HDMI?
The studio version (with LCD) looks very nice too.
Just got a reply from BlackMagic and the HyperShuttle is NOT made for shooting in the field.
CONS:
- Battery lasts for 1 hour
- No mounting ability to camera
However he did mention that some third parties may make some kind of mounting device. But the battery situation really licks.
Odd, because the marketing piece I just received said the following:
"Dramatically improve the quality of professional or consumer cameras! HyperDeck Shuttle gives you the quality of uncompressed recording direct to common low cost SSDs in the smallest possible size! HyperDeck Shuttle is compact, affordable and battery powered so it’s perfect as a field recorder." (The italics are mine.)
What I'd really want to know, and I hope the first people who get the hyperdeck can report, is whether I could loop through the SDI to HDMI port on the hyperdeck WITHOUT recording, and preferably without even having a disk in the bay. Namely, use the hyperdeck as a pure SDI/HDMI converter.
Since the hyperdeck costs about the same as a converter, the uncompressed recording part, which I don't really need, would then be just a freebee.
got mine from tekserve
after removing the shrink wrap, the first thing which i liked was the box, sweet design. has extra flaps on the side.
The recorder itself has a good build quality and is a very minimal design which does not disappoint.
I wish it had a 1/4'' mount so i could rig it easy.
AFAIK most dslr's HDMI output 1080i so this is annoying if you are used to progressive.
we will do some tests with the 5D and the 550D.
I wish i spent the extra bucks to get the sdi input on my carrion monitor which i bought from luis.
Also I'm still not sure which camera i will use with this recorder...
any suggestions?
Well so far, people are waiting for a firmware update to use it with the FS100, so as of right now, it does not work with the FS100.
any suggestions?
How are you using it with a 5D? Cropping out the pillarbox, and letter box in post?
Any info you guys could provide on wether this thing works as a loop through would rock,
DSLR HDMI to Hyperdeck HDMI in and SDI out to monitor,
just how it handles the res shifts and all the things that make DSLRs horrible for video village!
Edit: Just found this in the FAQ seems encoraging (but wether it works with HDMI in....):
[h=3]If I am recording SDI, will the HDMI output be available for preview? [/h]Yes, all outputs are available when recording or playing back. For instance, you can record SDI but preview on both the SDI and HDMI outputs.
This is correct, though I am using HD SDI out of a GY-HM750 to Hyperdeck and loop through HDMI to see the resolution on my 42" HD Bravia, as per FAQ question.
This device is F#@*ing unreal.
I really got my $345 worth.
I have ordered a PIX 240 but I can still see myself using the Shuttle quite a bit.
My system copes well with the uncompressed QT movies which play in real time, even with effects, in Premiere CS5.5
Quadcore 2.7somethin(8 cores), 2 500 Gb Seagate 7200's in raid 0, GTX470, Windows 7 x64.
I get 1 minute of 1080 at 25p for 6 Gb's on a Corsair 115Gb SSD that cost me $200.
That's roughly 18mins of uncompressed HD.
I think my bit rate is under the advertised rate due to the GY-HM750 only being 8bit(I think).
I can see the noise my camera outputs when looking at it close up on a 42" HD TV, but it looks ok after effects have been applied and is output in uncompressed, and it looks pretty damn good compared to what is broadcast to my TV.
I don't plan on shooting events with this so it's an attractive option for production.
It's possible to download to a backup drive in the field so 1 or 2 of these drives would do me.
A nice addition to my kit.
NOTICE
I think I have solved the mystery of the lower file size than advertised.
I was seeing jumpy motion in footage on the Shuttle.
I thought it was due to shutter speed on my camera but now I realise I am having serious problems with dropped frames.
The Corsair Force 115Gb is not recommended by BMD, and for good reason.
It isn't fast enough for the Shuttle.
Yea, it is actually one of BMs high quality SDI to HDMI and vice versa adapters that comes with a free uncompressed recorder.
Frank
You are right.
But I was also wrong because it is possible to have SATA II SSD's that perform better than SATAIII's, no?
So can the shuttle only record uncompressed? Cause on a 240GB SSD it's only 28 minutes of HD, cause it would be nice to be able to record a full music concert with it, I mean, you don't want to sit with terrabytes of footage for that?
thanks,
derrick
Uncompressed only.It´s not for this kind of work- more for narrative, commercials or VFX.
Since HDDs cost next to nothing today disc space isn't an issue anymore IMHO.
Horses for courses-if you want to record an concert with low bit rates, look at the Ninja or other compressing recorders.
Frank
Just don't go for a Ki Pro Mini... Used it to cover an entire music festival (in hopes that I could hot-swap), but despite there being two CF slots, it turns out there is no hot swapping... I have been told to go for the NanoFlash
Thanks Frank, just wanted to make sure it does not have any other options.
The Ninja/Samurai seems to be more suited to concerts and music videos.
thanks,
Derrick
Got a prototype of a great mounting plate and bracket from John Saunders at Connectivity Group:
Rock solid with plenty of 1/4-20 and 3/8 threaded holes.
