Thanks Alan.
This is way too complicated... I feel bad for CD as their engineers have to get around licensing agreements and Sony's 2K problems and still want to give us what we want.
I love the design of the CD package with the nice monitor and touch screen and all, compared to Sony's ugly and otherwise functionless LCD bricks.
I would love for CD to release a 'good enough product' ASAP and tweak it with firmwares later. I think once they get real customer feedbacks they can provide better upgrades.
Actually it's a lot more problematical than that. It's that they're trying to extract 2K raw off of a 4K raw sensor, while not changing the field of view. And that leads to some skipping of rows and colums of pixels, and that can cause aliasing and moire patterns.As regards the 2K raw 'problems'. As I see it, the 2K RAW 'problems' are caused by the fact that the resolution of a 2K RAW image once debayered is less than that of a true 1080p image. You'll get more aliasing because the resolution is lower.
But I'll make you a bet that the 2K raw off the Epic is quite a bit more "solid" (i.e., no aliasing, no weird artifacts) than the 2K off the Sony will be. The Epic windows down to sample a native 2K off the center of the sensor, so there's no additional aliasing introduced. Sony instead decided to prioritize maintaining the same field of view -- and that means they have to basically point-sample the sensor, and that is what will cause the aliasing.TBH the 2K RAW you get from an Epic ain't that great either.
I wish they would, then you'd have the best of both worlds.I wonder why they wouldn't just make it a choice. Simply have two options in a menu: 2K "normal FOV" and 2K "crop".
I'm sure they could, but that defeats the purpose of why one goes to 2K on the FS700 in the first place, which is to get higher frame rates... You could always do a 2K extraction in post if that's all you wanted, although I would think you'd find you'd get better quality by keeping the full 4K and downrezzing it to 2K, instead of just extracting the central 2K.Perhaps CD could somehow capture a 2K-resolution sample from the center of the 4K RAW stream with the 7Q?
Porsche intentionally cripples their Cayman model so they don't upstage their old icon, the 911. It wouldn't surprise me, at all, if Sony didn't want to make the FS700 too capable, as it would upstage their Cinealta product line at a much lower price...:kali:
Hi Dan
Earlier in the thread you mentioned that the 7Q would not be able to do 1080 at any frame rates faster than 60 because the signal the 7Q gets from the FS700 is 4K.
But over the last pages you also stated that the 7Q would be able to record 2K at 120fps.
The above two statements seem contradictory. Can you please clarify when you have a minute?
To answer your question though, for now I would vote option #2, especially since you said option #1 would take you far longer.
But being able to overcrank at 240 or even 120 at a better codec than AVCHD is extremely important.
Hi Dan,
Iis there going to be any type of screen protector? I love the disposable Small HD snap on screen protectors. Anything like that in the works or even an iPhone style thin stick on plastic sheet? I would hate to scratch the 7Q
Dear ChromeBoy007
The output of the upgraded FS700 in HD mode is limited to 1080p60.
The output of the upgraded FS700 in 2K Raw mode is limited to 240 frames per second.
The output in 4K Raw mode is limited to 60 frames per second.
(The FS700 can write 4K to cache at 120 fps, but this is limited to around 4 seconds and is output at a slow rate.)
Thus, it depend on what source we use, plug other factors, to determine what maximum fame rate we can achieve in a specific mode.
I hope this helps.
Respectfully,
Dan Keaton
Convergent Design
The CD site for the 7Q has "ARRI, Canon, Sony and user-loadable LUTs" as a feature that will be added to the device. I don't know about outputting a LUT'd image.Dan, Will we be able to upload custom luts shooting log to the 7Q or would we have to manually adjust within the monitor. Also can that lut be exported to a second screen or village? Thanks Stan
That is great. Thanks Dan. Now hopefully CD and/or Sony will solve those 2K problems.
