morgan_moore
Major Contributor
For the cleanest possible images, set the camera at 0db (which is 800 ISO) and rate it at 800 ISO. So long as you don't have blown highlights to worry about, that'll give you the cleanest, least noisy images possible.
Indeed Im all over low ISO where possible. Your gain 0:0:0 comment piqued my interest in considering if the EI modes in Slog are different to the gain on the switches, and also if they are additive. And also if they perform differently in their noise characteristics.
Ie does "gain=1600ISO SlogEIoff" make the same file as "gain=0 SlogEI=1600"
An emperical guess is that if they perform differently then the OP should use gain not EI to get a cleaner file where there is not enough light to expose at base ISO.
S
