Not my work, but pretty nice shots for an $800 MFT camera...
B&H Photo : Z CAM E2C Professional 4K Cinema Camera $799
I'm fairly interested in this camera, it's cheap and BMD hasn't (yet) brought out a new micro cinema camera (with SD cards that work). I think I can live with the 11.5 stops of DR that they claim.
A couple of months ago, I posted that there will be no GH-6 and, if there is, it won't be anywhere the GH-4/GH-5 price points. Most folks disagreed but, IMO, having an MFT 4K Raw camera retailing at $800 makes an appearance of even a 6K GH-6 far less likely going forward.
GH-5 was what, $1,800 upon release? Now you can get a full frame Nikon Z6 for that amount.
A7III and EOS R are $2,000 and also full frame
Finally, Panasonic's own full frame S1 is $2,000 (w/out the V-Log key, add $200 for V-Log).
And then there'll be a bunch of APS-C models in the $1,000-$1,300 range to slot below the full frame.
Now you can get a full frame Nikon Z6 for that amount. A7III and EOS R are $2,000 and also full frame. Finally, Panasonic's own full frame S1 is $2,000 (w/out the V-Log key, add $200 for V-Log).
And then there'll be a bunch of APS-C models in the $1,000-$1,300 range to slot below the full frame. And they'll likely to have some form of a Log too.
I've heard its basically a GH4 sensor. Not if it can do prores and RAW that is definitely a step up and not bad for $800. For just a bit more I'd probably go with a Pocket 4k though.
I'd read someone testing the "16 stops WDR" is that "HDR'd" alternating ISO thing where movement gets blurry tween those alternating frames
So something like the RED HDRx system where the camera takes a normal exposure and a second much shorter exposure, and then these two exposures are combined in post like HDR photos.
Sigma pf has the same feature.
Z Cam E2G is global shutter, not sure if it is out yet, and "only" going to be 4k.
