Mitch Gross
I'll ask the engineers.Any hope for proper audio time code (in separate waf file) during RAW shooting? Manual synchronizing in Resolve slows down RAW workflow much![]()
Can you explain how the 7Q and camera need to be configured to record 4K2HD 120fps bursts?
I'm keep getting a "format unsupported" message.
We are looking at ways to minimize the scenarios in which ne needs to reload the system. Currently the suggested method is to load the two that you would use most of the time and then it is only a few seconds to switch between them.
I've only seen that when I had the output on the FS700 still set to 60P. As soon as I turned it to 24 or 30P, everything worked fine. You can record 4K>RAW at 60P, but not when going to Prores.
If you're trying to do 120P, set your 4K output on the FS700 to 24/25/30P and then go into S&Q, set your framerate to 120 and then attach your SDI cable to the 7Q.
Indeed, we have an aggressive plan to continue growing the functionality of the Odyssey product line. As much as I'm excited by what we just released in this latest firmware, I'm more excited by what will be in the next one. And the one after that. And the one that follows. And we keep on going.
Remember, we are planning to release something once a month for at least the next few months. That's twice the rate of firmware updates as last year. We have hired additional staff in all departments and we mean to do this right. The success of the Odyssey products helped Convergent Design grow revenue fourfold last year and double its facility space. We're putting all of that to good use.
Well, that's encouraging, since I was waiting to get ProRes 444 with this update.
Btw, since you're the expert, I have an issue, most likely due to being a newbie at this. I have FS700+C7Q combo with Canon's CN7x17 lens. I recorded 4K ProRes 422 file just to test things, and it is quite noisy in the shadows in comparison to 4K RAW. I know this is probably more a camera issue than C7Q issue, but what C7Q IRE levels shown in the OLED you would consider safe to keeping shadows clean? Also, how much can I go over 109 IRE (or none?) before I can't pull highlights back in Resolve?
I have lifted my false colors levels about 10-20 IRE in general, to get noiseless pictures. I consider everything below 20 as black...
Yes, it sacrifices some DR, but its just about balancing with light, and the DR is there if i need it in a pinch. For example nature photography where i cant light the whole mountain...
