Hi,
I consider myself an amateur videographer with pretty good knowledge of a wide array of topics in the field. Here is my issue. I have a t2i, I have magic lanterns (june 7th update) I have my iso set to 160 native ISO am using 1/48 second shutter speed, and have picture style on technicolor cinestyle with sharpness at 0, contrast -4 and saturation -2. I have a 50mm 1.8 EF and a 17-55 IS 2.8 lens. I have a class 4 card and have my Qscale set to -14. My camera records fine and I use focus assist to aid in focusing. Heres my problem. I see people get great results from this camera and the lenses I have (example http://vimeo.com/13994916 - especially at 1:00) I understand composition, lighting, etc goes into making great looking pieces, But whats that quote? garbage in = garbage out. When I record , ALL my footage is soft and never is as sharp as others I have seen on vimeo/youtube. Also I see compression artifacts when recording close up shots even though my qscale is set for a high bitrate and I use a low ISO. Does anyone know, or can point me to a tutorial on how to get a good starting image from the t2i so i can grade it and play with it to make it look the way i want? Could there be a minor issue with my canon sensor, if thats even possible ? or do I just suck. I've tried stopping down but I still get a softer focus and artifacting. Please look at the example link I posted and give me some pointers. I appreciate any help.
PS - I used to have an HV20 with a dslr adaptor and was able to get good results from that so i know a little of what I am doing, just can't get the tackness down on the dslr.
