Do you mean the monitor is visible in the image, incidentally or you'll be framing a full screen?
Whenever I'm confronted with this problem I just use a camera that has "Clear Scan" or an "ECS" function as Sony calls it and just keep adjusting the shutter speed using the Clear Scan/ECS switch or scroll menu until the flicker / rolling frequency bar is dialed out. If you are using a DSLR I think you are not going to be able to overcome the problem easily. Sony brought out Clear Scan/ECS on a range of their cameras for the specific reason of shooting CRTs. Alternatively you could possibly hire a Sony DSC-1024 Converter that can go into the monitor line before the monitor as it can put out a recordable video signal of what is seen on the CRT.
Chris Young
Just wanted to say that I was able to adjust the shutter through Magic Lantern to perfectly match the fresh rate of the CRT and I've got what I needed. Thanks.
Magic Lantern to the rescue...AGAIN.
Love that stuff. Brilliant work those people have done.
It's great stuff for sure. Wish it was available for the 5D Mark IV. I had to go out and buy a used Rebel just for ML.
