Ben_B
Here is a rig I will be using to shoot some stuff in a classroom...not sure if I will be using the kit lens but I figure I should probably have enough light, it has big windows, and auto-focus will be nice in a pinch, especially if I need to zoom in or out. I will be running off of batteries because I have two and will have chances to swap (it's students doing spiels and they class talks between them) and I can have one charging and one in the camera, I'd rather not run the risk of someone tripping over a wall outlet or the power going out and blowing a take.
I will be using the Røde video mic on top of the Gh1 for sound...the sound quality doesn't have to be great, just hearable and clear, so it should be fine, however I will be using a Zoom H4 (not N) with AC power (because it goes through batteries soooo fast and because sound quality is better on AC power) for backup sound in case the AGC decides to go crazy on a take, and because I have been having the occasional problem with external mics on my GH1 ever since a 2.5mm adapter got bent out of shape while inside the plug. I've been running tests with the mic though and everything seems to be working, although I can duplicate the problem if I move the plug and cord around too much...I figure I will find a place that works and not touch it, and check the takes afterward...but again, will have the zoom as backup. I can't seem to get the mic to hook work with the zoom even with the right adaptor, and the zoom audio is a little quiet for my taste anyway, and since the onboard sound is good enough for this project I will go with it over syncing. Using the zoom also lets me monitor audio, which is good, even if it's not the audio I will likely be using, because I can tell if say, an air-conditioner that just turned on, will be a problem or not.
The grip is an old flash handle with a cold shoe that I got with an Olympus Pen FT I won on ebay.
I will be dumping cards on the fly with a netbook and USB HDD, one copy on netbook SSD, one on USB HDD.
I will also be using an Ikan V8000 HDMI monitor that is not attached to the rig to review my test shots when I first set my equipment up, and to review some of the footage during breaks to see if there is anything about my shooting methodology I need to adjust.
Anyway, lot of text for a very simple rig, but I figured someone would be curious what people are doing with their cameras. This is also the rig I will be using (sans zoom) for simple handheld work, and it actually does make things quite stable.
This project is mainly to simply capture the event so the students have reference for their own purposes, so it doesn't have to be amazing, it just has to work. I set up this rig and shooting methodology (audio backup, monitor checking, kit lens auto-focus, powered zoom, battery camera) around giving myself maximum redundancy and reliability...something you don't always get with these cameras.
