.MXF Problem : playback freeze at 30 seconds
Gridspace
Hi DVX users. Simply want to share a problem/solution. I only had access to the first 30 seconds of my .MXF in P2CMS during playback. In FCP every clips longer was cut to 29sec22frames (Bin & Timeline).
The problem was the Calibrated Q MXF Import v 1.6 application by Apple.
I uninstalled (link to pdf) it manually and everything is back to normal.
Is there other users with the same issue?
cheers
Actually, Adobe Premiere CS3 accept P2 format, I don't see why we still need a third party application to read MXF in Final Cut Pro !
What's coming?
I doubt it is mxf native support in FCP.
Apple wants to stay with QT wrappers -- at least it has.
Do you have some info?
