KyleProhaska
I think the range here is actually quite remarkable. The highlights as previously stated are held very well. Looking at the 720p version I can tell the sharpness setting on the camera was far too high. It's apparent the most in the wide shots. The one at 0:39 that everyone is mentioning shows lots of sharpening around the edges. This will be fixed with the settings being dialed in. Calm down folks, this is no different than the DSLR's where you drop the sharpness. It's the same problem and it's not really a problem at all. Easily fixed with settings
I do really like the skin tones. I keep finding it tough to get the skin tones I want with my footage. It's so tough to fix in post if you get it wrong or want to edit it. Also the footage does seem a bit lower rez than I thought, but it might be looking worse because of the sharpening? There's a bit of noise in a lot of the shots as well. Again, all of this will likely be minimized by the different settings that can be altered to pull out the best quality possible.
We'll see how things turn out...
