Matt Sconce
msconce said:Noise Removal Tutorial:
Step one, Export from Premiere Pro 2.0 in Uncompressed Filmstrip format for After Effects. Step two. Import into After Effects. Drop into a 23.976 composition. Set the composition several frames beyond what your clip length is. Apply Remove Grain. Change the viewing mode to final output, instead of preview. Fiddle with the Noise reduction slider under the noise reduction settings. Try to get a mix between the most detail and the smooth picture. If there is a ton of noise in the background that just seems to not go away, bring the slider down to about .2 and then enable temporal filtering. Set it to 100% and bring motion sensitivity to .9. Observe the results and then play with the noise reduction slider again until you achieve the look you want. It will make much more minor of a difference when temporal filtering is one, but it does help.
Output as an Uncompressed Quicktime or AVI format. NOT as a filmstrip again. For some reason if you export as an uncompressed filmstrip, it stretches the clip and makes it stuttery.
I hope this little tutorial helped!
The first page has been updated to include it.
:grin:
Does anyone have any other methods of Noise reduction that have worked for you?
I am about 1/3 of the way through Stricken noise reducing. It takes a long time, becuase each scene is different and a blanket noise reduction would not work. I am happy with it though.
After this, I will make the Encore Menu...I am still new at that so we shall see how it goes, then I should receive the score fro Leo, lay it all together and Stricken will be born.
Has anyone gotten their DVD's professionally Duplicated? Glass master and all... I am wondering if I make the DVD in Encore and send it to them or if I send the m a file, or what? hmmm..... I'll keep you updated.
