Per the B&H DSLR Guide, "Unlike video cameras, HDSLRs (except for the Panasonic GH1) lack reliable autofocus, so the user will need to hone follow-focusing skills." I'd like to ask the Forum how difficult is it to "follow focus?"
Hollywood dedicates an entire crew position to this SOLE duty. It's called the first camera assistant (aka 1st AC). Their sole job is to focus. It's not an easy skill to really MASTER.
I'm probably splitting hairs, as you likely know this. But the 1AC has focus as a primary responsibility, but not thier sole responsibility. They are also responsible for the camera kit, and camera setup.
Manual focus is on you. Your responsibility. If you screw up, it's your fault.
It's difficult. If you're perfect, everything will be in focus.
Nobody's perfect. But if you can plan your shots, you can
nail focus.
AF is on the camera. It's pretty good. It will definitely
screw up, and you will lose shots. But most of the time
it is better than you, especially in a dynamic environment
when you have no plan. Except when it decides to hunt
for something you have no interest in hunting, which it
will, especially in low light
If you're in a situation where you need to cover every moment
in front of the camera you better go manual focus. If you are
covering an event where you can afford to throw away some
bad shots, and just need a preponderance of good ones,
you can rely on auto-focus.
