Magic Lantern Firmware
M. Gilden
Canon DSLR Moderator
So, you've got a DSLR camera capable of surprisingly good looking HD video. Yet, it lacks the basic video camera features you're used to because it is clearly designed to be a still camera first.
So what do you do if you intend to use this as a video camera, and just can't live without some of those features?
You install Magic Lantern, that's what!
What IS Magic Lantern?
For the whole story, I recommend reading their Wiki here:
http://magiclantern.wikia.com/wiki/Magic_Lantern_Firmware_Wiki
But in a nutshell:
Its a custom software suite of additional features written by some users who were brilliant enough to be able to reverse-engineer some of the code Canon uses to control the camera's functions. It doesn't actually REPLACE your camera's firmware, but sort of runs on top of it, loading off the memory card upon boot (that means if you decide you don't want it for a shoot, simply remove the card that has it installed or reformat it).
What does ML add?
Too many things for me to list here, but some of my favorite examples include:
  • Manual Audio control (with the ability to control both analog and digital gain)
  • Live audio meters displayed on screen during recording
  • exposure zebras
  • live histograms
  • live audio monitoring using headphones (plugged into the AV out jack) during filming
  • focus peaking
  • focus assist tools with live magnification area (this is a must IMO, if you intend to be able to pull accurate focus while using the built in LCD)
Is Magic Lantern safe?
Anything of this sort will likely void your camera's warranty if they find out you did it. However, if I understand correctly, even using a third party lens like a Sigma or vintage Nikon w/EOS adapter will void your warranty.
As far as breaking your camera- there is a standard obligatory disclaimer that this may in fact cause damage to your camera. However, I have not heard of anyone causing any kind of permanent damage yet.
To quote their Wiki:
As of September 2009 the software has been downloaded over two thousand times and there have been no reports of damage to the cameras. While this is no guarantee of absolute safety, the stable releases have been tested by beta testers. Most of the risk is to the developers' cameras while testing new features and probing new portions of Canon's firmware. By the time the software moves from development to beta testing it has been installed hundreds or thousands of times.
Still, if you are not comfortable with this sort of thing, no one is forcing you. If you are the sort of person who inevitably misses a step, skim reads, or otherwise finds themselves and technology not getting along, perhaps this is something you should sit out for.
But if you are motivated to do this, read all the instructions and follow them carefully (including warnings), the software is very rewarding to have.
Does Magic Lantern work on my camera?
Magic Lantern was started by Trammel Hudson on the 5D, but was soon brought to the APS-C sized T2i/550D (original forum discussion on this topic here: http://www.dvxuser.com/V6/showthread.php?218686-Magic-Lantern-for-550D-in-progress! ), and eventually made its way to the 60D and T3i. This was after fruitless attempts to bring it to the 7D led to a brick wall (UPDATE! Progress is now being made on the 7D!).
There is now a unified Magic Lantern build for most of the current Canon video DSLRs, including the t2i/550D, t3i/600D, 60D, and even the 50D. 7D was thought impossible due to the different way the processors work, but it is now being worked on (as of 10/15/12).
This unified version is now the official version for all supported cameras, and replaces any individual builds that preceded it.
The Wiki for this unified build can be found here:
http://magiclantern.wikia.com/wiki/Unified
with installation instructions here:
http://magiclantern.wikia.com/wiki/Unified/Install
and the user guide here:
http://magiclantern.wikia.com/wiki/Unified/UserGuide
Meanwhile, not all features from the T2i version of Magic Lantern have been successfully ported to the other cameras yet. For example, audio monitoring on the T3i does not work, and the focus tools on the 60D are unstable. For a complete list of what works (or doesn't) on each camera model, check the chart here:
http://magiclantern.wikia.com/wiki/Unified/Features
UPDATE: Magic Lantern is considered stable and final for many cameras, and has now become a commercial product in its latest form. The new official site can be found here: magiclantern.fm
The 7D, despite being an iconic camera used in recent films, does NOT have a stable Magic Lantern version available yet. This is mostly due to the way Canon designed the camera- unlike the other DSLRs from Canon, the 7D uses dual DIGIC processors that change the way it executes code versus the other models being discussed here (which all use a single Digic chip).
Good luck!
Thanks a1ex- I actually did mention in the first post that the 5D has it, and got it first.
I didn't make a big mention because the 5D has its own section of this forum. The links are very helpful tho, thanks!
Magic Lantern and Technicolor CineStyle Picture Profile
Can I load the Technicolor Cinestyle Picture Profile onto my T2i if I already have the Magic Lantern? I don't want to brick it.
Apples and oranges, my friend. Magic Lantern adds a layer of functionality on top of the camera UI, it doesn't actually change how any of the regular functions work. Different memory space, etc.
Hi all, I would like to install Magic Lantern on my 60d. However, in the Magic Lantern installation instructions, it says for the 60d: "Upgrade [Canon] firmware to 1.0.9. If you have firmware 1.0.5, you must upgrade first to 1.0.8 and then to 1.0.9.
My 60d does indeed have 1.0.5 firmware. I looked on the Canon website, and they only have firmware version 1.0.9.
So, can I upgrade my Canon's firmware directly from 1.0.5 -> 1.0.9, and then install Magic Lantern 1.0.9?
(Apologies for crossposting this exact question on a related board.)
FYI, I successfully updated my 60d Canon firmware from 1.0.5 directly to 1.0.9, with no issues.
A1ex, does this mean I am now able to install ML on the 60d without any problem?
(If yes, the instructions for installing ML onto the 60d should be corrected.)
I just got my T2i in today and I cannot install the MagicLantern software. I'm at the step where I need to copy MagicLantern.fir onto the formatted (low level) SDXC card and my T2i says "Cannot find firmware update". Also my T2i is properly updated to 1.09. What's wrong?
Figured out the problem, the magiclantern.fir step has to be done on an SDHC card and NOT an SDXC card. However the autoexec file CAN be on an SDXC. Everything works now!
One more question: How do I get White Balance to be back to AUTO? Magic Lantern doesn't appear to allow me to do this just "auto tuning" but not auto? NOTE: This is in Movie Mode.
To use auto white-balance you need to use the default Canon menu. You can do this by accessing the Q-menu. If you had a Kelvin WB temp selected, then the space where the WB icon should be in the Canon Q-menu will be blank, but you can still highlight the blank space and make changes using the top dial.
+1
Remember, the Canon functions in the native menus still work, however ML can let you set them to new values (ones that the original may not have presented to you). Going back and changing the setting in the Canon menu will still work as expected.
The same is true of, for example intermediate ISO values. If you set the ISO to 640 in ML, then use the regular Canon controls to set it back down to 200, your ISO just changed from 640 to 200, regardless of which menu it was accessed from.
Dear Mr Gilden,
can I suggest incorporating the following links into your opening post?
Unified user guide - http://magiclantern.wikia.com/wiki/Unified/UserGuide#histogram
U
nified installation guide - http://magiclantern.wikia.com/wiki/Unified/Install#Step_2._Installation
D
ownloads page - it's all here - http://magiclantern.wikia.com/wiki/60D
H
aving all these resources on the one page might help those who are starting out and finding the extensive resources on the whole ML thing a bit intimidating. It's big news that ML for aspc cameras is now unified too. Congrats to a1ex for all the graft..
Having an issue with cropmarks that I didn't see mentioned in the manual anymore. In an older release-around January I think, we were able to have cropmarks in playback mode by pressing "Q" when the cropmarks feature was selected. For the past couple months, I haven't been able to figure out how to get them in playback. I see the all modes function, but that doesn't do it. Has this feature been disabled?
