Are you trying to sync with a separate wav file or with external audio? I am just asking because last time I tested with my Zoom H2 audio file, it did sync fine. Perhaps I didn't try syncing a longer take.
Separate wav..
External audio syncs fine. Internal audio is losing packets, and thus goes out of sync in a way that can't be fixed with just one sync edit (must be cut & resync'd multiple times).
Squig, few questions (sorry for not reading far enough, trying to maximize my time with it tomorrow and can't find these answers):
1. Is it normal for the current June 3rd build to place the last DNG from the prior file at the beginning of the following clip?
2. Have you witnessed any issues with Orange or Red colors? I'm seeing burnt oranges are turning pink, or hotter orange turning pink. (Using Neutral)
3. How are camera profiles (Neutral, etc) affecting color? Any tests?
4. Have you observed any different behavior in regards to color when setting white balance to daylight or tungsten under a specific temperature (as in shooting daylight when the scene is clearly tungsten, but white balancing in post). I ask this because it does seem like things are being "baked in" in a way, and I wonder if this is doing anything one way or another. Probably shouldn't, but this also probably shouldn't exist (yet) in the first place.
Thanks.
Kholi,
Can you shoot a RAW still with a grey card in the frame of the same image and post it for comparison? I am looking forward to trying the RAW video on the MKIII as I shoot a lot of RAW stills but am too busy for the next month or so. I have found the colors in LR along with a custom profile I created in the Adobe DNG profiler to have amazing color accuracy. This is for stills so I wonder if something gets skewed on the video side.
