Saddler said:Can I start a capture via FCP on a Macbook and then close the macbook to place in a backpack while filming, or does that unavoidably put the computer to sleep?
GroovyBrent said:I don't know about the MacBook Pros, but with older Powerbooks, you could close the lid and the computer would stay running IF you had an external monitor hooked up. They were specifically designed to run this way, so heat wasn't an issue (as long as the side fan vents remained clear).
Assuming the MacBook Pros worked this way, if you could trick the computer into thinking there was an external monitor (maybe with a blank DVI connector?), you could run with the laptop closed. However, I wouldn't place it in a backpack, or any space where there wasn't adequate ventilation.
sbove said:I don't want to have to open it and use menus every time I start a capture (very hard in nasty environments (beaches, citystreets, deserts, playas, snow, rain)...Best case would be to start the capture once
sbove said:ps: has anyone heard of replacing the 120GB internal drive in the macbook pro 17" with something larger???
