Hi Fellow sound guys! I am just getting into Location Sound Recording, and have done a few short low budget films. I have some questions that I am having trouble figuring out on my own, and I apologize in advance for my long winded question's/ramble.
My two main questions focus on recording methods and appropriate dialogue levels.
1) When recording a master shot in a dialogue based situation where the DP has made the frame too wide to be able to get close boom coverage providing low S/N ratio, and their aren't enough wireless radio mic's (or channels on the mixer(SD302)) to cover all the talent. What is the appropriate response and practice to still record quality usable dialogue, or is this just not an option based on the provided set up?
As a general question, what do people do when recording master shots with dialogue?
Typically when recording more than three actors I have put two wireless mic's on the talent and tried to boom from up high, but this obviously only covers some of the dialogue with the wireless and then the rest of the tracks are echoey and with a high noise to signal ratio. Do other mixers turn up their gain and just deal with the recorded noise in post? I have tried planting mic's but this is difficult to count on when concidering available production time, sporadic actor movements, and the physical reality of a location. When communicating with the picture department, we have agreed to just use the sound from the Master shots as a Guide track for intercutting the mediums and close ups or cutting out the recorded close-up dialogue and editing it to fit the master later. Although while considering my limited experience with editing sound, when using just lapel mic's in a Master and then trying to mix it in post the shotgun and lavs are quite difficult to match, even when adding reverb to the lapels. Additionally, I know it is important to maintain constant recording levels throughout a scene, when considering that a mic can't be placed close to the actor's mouth in a master shot, do mixer's turn up the Pot to make up for the difference to a medium shot regarding actors levels?
2) I also tend to have dramatically fluctuating signal levels when recording dialogue. In general I find that they are too low. In my last shoot I made a serious effort to request that the talent speak louder when their levels were coming up to low on the mixer. Is this a simple reality of doing sound mixing, or is there possibly something I am missing?
Here is my typical set-up;
MKH-416 shotgun mic AND TR-50 lavs with if needed G3 Transmitter/Receivers (once Lectrosonics)
-mic in- with48 phantom power, to-
Sound Devices 302 mixer (three channels)
-Line out to-
Tascam DR-100 Mkii Recorder (two channels) WITH a confidence return to the MIXER (which I stay on when I am recording)
Recording 24/48 quality onto two channels with a scratch track to the camera typically using a 1/8 cable.
At the beginning of each set-up I check my levels sending a 1k tone through the loop to calibrate the mixer to the recorder
For whispers or soft Dialogue I try to have levels between -30dBFS and -20dBFS
Average Dialogue between -20dBFS and -12dBFS
Loud Dialogue between -12dBFS and -6dBFS (placing the limiter around -3 on the SD 302 mixer
I would really appreciate any comments or advice that people have.
Thank you for your time and for reading my post!!
-Line out to-
