about level - usially the dialog for movies recorded with picks which fly -8-10 dbfs what give you another 8 -10 for unexpected signal ( 0dbfs - is the highest point on mt scale)
with normal setting the O dbu on your mixer will give you -20 dbfs on mt scale , since you dont know where is it try to give your mixer signal which will light the last red , this is 16 dbu and calibrate the tone to the maximum , brick wall , now decrease the level by 4 dbu and check where is the meter now
increase the level again - and calibrate the +16 dbu as -4 mark you found on mt scale
now you give 0 dbu tone and it show you the -20dbfs mark , make a sighn there with the marker
now you can work normally as normal people work and go to the red
place your limiters at +16 dbu
for tv stuff usially the +10 dbu is the maximum this came from fast editing and satellites tracks) so you keep your recording lower before you make all this check if the maximum signal from your mixer( +16 dbu and Little bit more
doesn't light the red led on mt input , if it does decrice the level on the recorder until it will despaired ,
easy , very easy . the 8 was sounding quit good , the levels where ok but you might go hotter
