Get better adapters, or adjust them with shims, or if they have some sort of adjustable collar. As long as the lenses you are using are designed to have a longer flange distance than what you are putting them on, you are fine. The E-mount is like 18mm or something really shallow, while PL mount, (what i use) is around 52mm, meaning there is lots of room for an adapter to do it's thing (which is to simply make up the 34mm of extra space needed between the lens flange and the sensor.
Sounds like your adapters have just not been accurate.
ps: I have a E-mount to PL adapter, so I'm super ready to do some tests.![]()
I've currently got a set of Zeiss ZF primes 18,25,35,50,85
I skipped the 100mm makro because it breathes so much that I can't use my mattebox on it
I was thinking of picking up a cheap Nikon 70-210mm F/4-5.6 AF to fill the long range that I'm missing
can anyone recommend this lens?
I think all CP 2 are mount interchangeable. This means that you can buy lets say the PL version, and buy the --to EF mount.
Can anyone confirm that ?
