Yesterday I finally did the GH13 hack on my camera and got it working. I did have some initial issues due to needing the newer version of pTool ver. 40d (who knew there were multiple versions of the same rev). So anyway, seems to work (using lpowells reliable AVCHD and MJPEG settings).
After getting this installed and working with my std. Panny lens (14-140), I put on my M4/3-Nikon adapter and got the "Lens Not Attached" error. Now before I did the hack, this was working OK, but I haven't seen this problem listed before, so it might just be a coincidence.
I have two different Nikon adapters, one with an iris screw adjuster and the other without. Both generate the same error. Even without the lens on, I get the error. If I push or rotate the front dial, the error message goes away for a short time but comes back if I hit record.
So my questions are, is it possible that the hack can have a side effect like this or is it probably something unrelated?
What conditions cause the error to be generated?
Is there another thread that addresses this?
What are your ideas for troubleshooting and solving this?
I just got a new Tamron 17-50 2.8 that I need for my shoots, hate to be limited to the slow panny glass.
Thanks for your help in advance!
