GH4 Just announced New 4K DSLR for $898 includes lens
Ken1212
Panasonic LUMIX DMC-FZ1000 Digital Camera
Product Highlights
  • 20.1MP 1" High Sensitivity MOS Sensor
  • Leica DC Vario-Elmarit 16x Zoom Lens
  • 25-400mm f/2.8-4 (35mm Equivalent)
  • 4K QFHD Video Recording at 30 fps
  • 0.39" 2,359k-Dot OLED Live View Finde
  • 3.0" 921k-Dot Free-Angle LCD Monitor
  • Built-In Wi-Fi Connectivity with NFC
  • HYBRID O.I.S. 5-Axis Image Stabilization
  • Light Speed AF with LUMIX DFD Focus
  • ISO 25600 and 50 fps Continuous Shooting
http://www.bhphotovideo.com/c/product/1057135-REG/panasonic_dmc_fz1000k_lumix_dmc_fz1000_digital_camera.html?cm_mmc=EML-_-Newsletter_Newsletter-_-140612-_-BannerT_Retail_Panasonic-DMC-FZ1000
VERY nice indeed. Missing things I need in my GH4, but could be a great B cam, and maybe better low light?
The best part about this release and price range panasonic states it will do 1080/120fps or 720/240fps
Don't know if this is a misprint or what but this is from BNH's site under overview 4k recording
"Additionally, high speed video recording is possible at 1080p, 720p, and 480p with sensor output frame rates of 120 fps, 240 fps, and 360 fps, respectively."sor output frame rates of 120 fps, 240 fps, and 360 fps, respectively."
Seeing as it's a bridge camera with a non removable lens- I'm holding out for the rumoured LX8 compact with 4K instead.
(idealy I'd want a firmware update on the GX7 but hey...)
This might be a good 4K B camera if you can live with the 30p frame rate.
Slow-Motion Modes
- 1080p 120fps
- 720p 240 fps
- 480p 360 fps
Still-Photo Frame Rates
- 50 fps with an electronic shutter
- 12 fps with a mechanical shutter
- 7 fps with a mechanical shutter and continuous AF
Still-Photo Focusing Speed with LUMIX DFD AF Technology
- 0.09 seconds (wide)
- 0.17 seconds (tele)
Looks like a great deal for a fixed-mount, remote-controlled 4K videocam. CinemaD, fast Leica, OIS, power zoom, 1" sensor - all good for stable, well-exposed footage with broad DOF. 30p NTSC (or 25p PAL) is a no-brainer for web and broadcast formats. My questions are whether the lens is wide enough and the mobile app capable enough for hands-off real-time operation in the field?
According to Andrew Reid the 4K mode has a FF crop factor of 2.7x which translates to a FF zoom lens equivalent of 37-592mm, so not very wide at all. I am hoping this means that the 4K image will be very clean with very little aliasing and no moire. ( I suspect the extra crop comes from the FZ1000's 20 Mpx sensor vs the GH4 16 Mpx sensor )
We've have a pre-order link up for the new FZ1000:
Panasonic DMC-FZ1000 Camera $899.99
ETA is late July, early August per Panasonic.
thumbnail.asp
It seems only 30p at 4K which would be a major drawback.
Dang. I was seriously eyeing this as a B-cam for my GH4, but I need 4k in 24p. That right there makes me instantly not interested in this new camera. Shame, since in pretty much every other way it seems perfect for me.
Yeah, no 24p is a NO-GO.
It does look a lot my Sony RX10…..
Now Sony needs to get on it and make a Sony RX40.
Panasonic DMC-FZ1000 Specifications
Playback Mode
Battery Life (Approx.)
360 pictures (CIPA Standard)*1 (TBD)
Standard Accessories
Please refer to "Accessories" Sheet
NOTE;
*1Recording conditions by CIPA standard
- Temperature: 23 oC (73.4 oF) / Humidity: 50%RH when LCD monitor is on.
- Using a Panasonic SDHC Memory Card
- Using the supplied battery.
- Starting recording 30 seconds after the camera is turned on. (When the optical image stabilizer function is set to [ON].)
- Recording once every 30 seconds with full flash every second recording.
- Rotating the zoom lever from Tele to Wide or vice versa in every recording.
- The number of recordable pictures varies depending on the recording interval time.
- If the recording interval time becomes longer, the number of recordable pictures decreases.
- CIPA is an abbreviation of [Camera & Imaging Products Association].
*2- These are standard times taken at a temperature of 23 oC (73.4 oF) and a humidity of 50%RH.
- The time available for recording varies depending on the environment, the interval between recordings, and the manner of use.
- Actual recordable time is the time available for recording when repeating actions such as switching the power supply [ON] / [OFF], starting/stopping recording, zoom operation etc.
- Use a card with SD Speed Class with "Class 4" or higher when recording motion pictures.
- Use a card with SD Speed Class with "UHS-I Speed Class 3 (U3)" when recording motion pictures with [MP4] in [4K].
(SD speed class is the speed standard regarding continuous writing.)
- Maximum time to record motion pictures continuously with [AVCHD] is 29 minutes 59 seconds.
- Maximum time to record motion pictures continuously with [MP4] in [4K] is 29 minutes 59 seconds.
- Maximum time to record motion pictures continuously with [MP4] in [FHD] [HD] [VGA] is 29 minutes 59 seconds or up to 4 GB.
- Maximum time to record High Speed motion pictures continuously is 7 minutes 59 seconds.
[TD="width: 101"] Specification Sheet for NTSC Area [/TD]
[TD="width: 152"]
[/TD]
[TD="width: 180"]
[/TD]
[TD="width: 37"]
[/TD]
[TD="width: 598"]
[/TD]
[TD="bgcolor: #00CCFF"]
[/TD]
[/TD]
[/TD]
[TD="bgcolor: #000000"]
[/TD]
[TD="bgcolor: #000000"] FZ1000 [/TD]
[TD="bgcolor: #808080, colspan: 2"] Metrics [/TD]
[TD="bgcolor: #FFFFFF"] Dimensions (W x H x D)
[/TD]
[/TD]
[TD="bgcolor: #FFFFFF"] 136.8 x 98.5 x 130.7 mm
(5.39 x 3.88 x 5.15 inch)
[/TD]
[TD="bgcolor: #C0C0C0"] Weight [/TD]
[/TD]
[TD="bgcolor: #C0C0C0"] Approx. 780 g without Battery and SD Memory Card (1.72 lb)
Approx. 831 g with Battery and SD Memory Card (1.83 lb)
[/TD]
[TD="bgcolor: #808080"] Optics [/TD]
[TD="bgcolor: #808080"] Pixels [/TD]
[TD="bgcolor: #FFFFFF"] Camera Effective Pixels [/TD]
[/TD]
[TD="bgcolor: #FFFFFF"] 20.1 Megapixels [/TD]
[/TD]
[TD="bgcolor: #808080"] Sensor [/TD]
[TD="bgcolor: #C0C0C0"] Sensor Size / Total Pixels / Filter [/TD]
[/TD]
[TD="bgcolor: #C0C0C0"] 1-inch High Sensitivity MOS Sensor / Total Pixel Number 20.9 Megapixels / Primary Color Filter [/TD]
[/TD]
[TD="bgcolor: #808080"] Lens [/TD]
[TD="bgcolor: #FFFFFF"] Aperture [/TD]
[/TD]
[TD="bgcolor: #FFFFFF"] F2.8 - 4.0 / Multistage Iris Diaphragm
(Still Image: F2.8 - 8.0 (W), F4.0 - 8.0 (T), Motion Picture: F2.8 - 11.0 (W), F4.0 - 11.0 (T))
[/TD]
[/TD]
[/TD]
[TD="bgcolor: #C0C0C0"] Optical Zoom [/TD]
[/TD]
[TD="bgcolor: #C0C0C0"] 16x [/TD]
[/TD]
[/TD]
[TD="bgcolor: #FFFFFF"] Focal Length [/TD]
[/TD]
[TD="bgcolor: #FFFFFF"] f = 9.12 - 146mm
(27 - 432mm in 35mm equiv. in 4:3)
(25 - 400mm in 35mm equiv. in 3:2)
(26 - 416mm in 35mm equiv. in 16:9)
(32 - 512mm in 35mm equiv. in 1:1)
(26 - 416mm in 35mm equiv. in 16:9 video recording / O.I.S. Off / Level Shot function Off)
(28 - 448mm in 35mm equiv. in 16:9 video recording / O.I.S. On / Level Shot function Off)
(31 - 496mm in 35mm equiv. in 16:9 video recording / O.I.S. On / Level Shot function On)
(37 - 592mm in 35mm equiv. in 4K video recording)
[/TD]
[/TD]
[/TD]
[TD="bgcolor: #C0C0C0"] Extra Optical Zoom (EZ) [/TD]
[/TD]
[TD="bgcolor: #C0C0C0"] 22.4x (3:2 / 10M (M)), 32x (3:2 / 5M (S)) [/TD]
[/TD]
[/TD]
[TD="bgcolor: #FFFFFF"] Intelligent Zoom [/TD]
[/TD]
[TD="bgcolor: #FFFFFF"] 32x [/TD]
[/TD]
[/TD]
[TD="bgcolor: #969696"] Lens [/TD]
[/TD]
[TD="bgcolor: #969696"] LEICA DC VARIO-ELMARIT
15 elements in 11 groups
(5 Aspherical Lenses / 8 Aspherical Surfaces / 4 ED Lenses)
[/TD]
[/TD]
[/TD]
[TD="bgcolor: #FFFFFF"] Changing of Zoom Speed [/TD]
[/TD]
[TD="bgcolor: #FFFFFF"] 5-Speed Zoom [/TD]
[/TD]
[/TD]
[TD="bgcolor: #969696"] Optical Image Stabilizer /
Five-Axis Correction
[/TD]
[/TD]
[TD="bgcolor: #969696"] HYBRID O.I.S. +* / Yes*
* Except for the 4K video recording.
[/TD]
[/TD]
[/TD]
[TD="bgcolor: #FFFFFF"] Digital Zoom [/TD]
[/TD]
[TD="bgcolor: #FFFFFF"] Max. 4x [/TD]
[/TD]
[/TD]
[TD="bgcolor: #C0C0C0"] Conversion Lens Compatibility [/TD]
[/TD]
[TD="bgcolor: #C0C0C0"] - [/TD]
[/TD]
[TD="bgcolor: #808080"] Focus [/TD]
[TD="bgcolor: #FFFFFF"] Focusing Area [/TD]
[/TD]
[TD="bgcolor: #FFFFFF"] Normal: Wide 30 cm - infinity / Tele 100 cm - infinity
AF Macro / MF / Intelligent Auto / Motion Picture: Wide 3 cm - infinity / Tele 100 cm - infinity
[/TD]
[/TD]
[/TD]
[TD="bgcolor: #C0C0C0"] AF Assist Lamp [/TD]
[/TD]
[TD="bgcolor: #C0C0C0"] Yes (On / Off) [/TD]
[/TD]
[/TD]
[/TD]
[/TD]
[TD="bgcolor: #FFFFFF"] AFS (Single) / AFF (Flexible) / AFC (Continuous) / MF
Normal / AF Macro / Macro Zoom, Quick AF On / Off (on in Intelligent Auto), Low Light AF, AF/AE Lock Button, AF Area Select, AF Tracking, Eye Sensor AF, Focus Peaking, One Shot AF (Set the Fn button in custom menu to AF-ON)
[/TD]
[/TD]
[/TD]
[TD="bgcolor: #C0C0C0"] AF Metering [/TD]
[/TD]
[TD="bgcolor: #C0C0C0"] Face/Eye Detection / Tracking / 49-area / Custom Multi / 1-area (flexible / scalable) / Pinpoint [/TD]
[/TD]
[TD="bgcolor: #808080"] Shutter [/TD]
[TD="bgcolor: #FFFFFF"] Shutter Speed [/TD]
[/TD]
[TD="bgcolor: #FFFFFF"] Still Image:
Approx. 60 - 1/4,000 sec (Mechanical Shutter)
Approx. 1 - 1/16,000 sec (Electronic Shutter)
Bulb (Approx. 120 sec)
Motion Picture:
Approx. 1/30 - 1/16,000 sec
Approx. 1/25 - 1/16,000 sec (AVCHD in FHD 24p)
Approx. 1/2 - 1/16,000 sec (Creative Video Mode / MF Mode)
[/TD]
[/TD]
[TD="bgcolor: #808080"] Finder [/TD]
[TD="bgcolor: #C0C0C0"] Viewfinder [/TD]
[/TD]
[TD="bgcolor: #969696"] 0.39" OLED LVF (Live View Finder) (2359K dots), Field of View: Approx. 100%, Lens XXXx
Magnification: Approx. 1.88x / 0.7x (35mm equiv.), Eye Sensor
[/TD]
[TD="bgcolor: #808080"] Recording [/TD]
[TD="bgcolor: #808080"] File [/TD]
[TD="bgcolor: #FFFFFF"] File Format [/TD]
[/TD]
[TD="bgcolor: #FFFFFF"] Still Image: JPEG (DCF/Exif2.3) / RAW, DPOF
Motion Picture: AVCHD, MP4
[/TD]
[/TD]
[TD="bgcolor: #808080"] Recording Modes [/TD]
[TD="bgcolor: #C0C0C0"] Mode Dial / Mode Button [/TD]
[/TD]
[TD="bgcolor: #C0C0C0"] Intelligent Auto, P, A, S, M, Creative Video, C1 (Custom), C2 (Custom), Scene Guide, Creative Control [/TD]
[/TD]
[/TD]
[TD="bgcolor: #FFFFFF"] Creative Control Mode [/TD]
[/TD]
[TD="bgcolor: #FFFFFF"] Expressive, Retro, Old Days, High Key, Low Key, Sepia, Monochrome, Dynamic Monochrome, Rough Monochrome, Silky Monochrome, Impressive Art, High Dynamic, Cross Process, Toy Effect, Toy Pop, Bleach Bypass, Miniature Effect, Soft Focus, Fantasy, Star Filter, One Point Color, Sunshine (22 filters) [/TD]
[/TD]
[/TD]
[TD="bgcolor: #C0C0C0"] Still Image Scene Mode / Scene Guide [/TD]
[/TD]
[TD="bgcolor: #969696"] Clear Portrait, Silky Skin, Backlit Softness, Clear in Backlight, Relaxing Tone, Sweet Child's Face, Distinct Scenery, Bright Blue Sky, Romantic Sunset Glow, Vivid Sunset Glow, Glistening Water, Clear Nightscape, Cool Night Sky, Warm Glowing Nightscape, Artistic Nightscape, Glittering Illuminations, Handheld Night Shot, Clear Night Portrait, Soft Image of a Flower, Appetizing Food, Cute Dessert, Freeze Animal Motion, Clear Sports Shot, Monochrome, Panorama [/TD]
[/TD]
[/TD]
[TD="bgcolor: #FFFFFF"] Continuous Shooting Mode (Approx.) [/TD]
[/TD]
[TD="bgcolor: #FFFFFF"] [AFS] SH: 50 frames/sec*, H: 12 frames/sec, M: 7 frames/sec (with Live View), L: 2 frames/sec (with Live View)
[AFC] H: 7 frames/sec, M: 7 frames/sec (with Live View), L: 2 frames/sec (with Live View)
* Electronic shutter only.
[/TD]
[/TD]
[/TD]
[TD="bgcolor: #C0C0C0"] Motion Picture Recording (*2) [/TD]
[TD="bgcolor: #C0C0C0"] 4K Video [/TD]
[TD="bgcolor: #C0C0C0"] 3840 x 2160 pixels, 30p (4K: 100Mbps / MP4) (Sensor Output is 30fps) (AAC) [/TD]
[/TD]
[/TD]
[/TD]
[TD="bgcolor: #C0C0C0"] HD Video [/TD]
[TD="bgcolor: #C0C0C0"] 1920 x 1080 pixels, 60p (FHD: 28Mbps / AVCHD) (Sensor Output is 60fps) (Dolby)
1920 x 1080 pixels, 24p (FHD: 24Mbps / AVCHD) (Sensor Output is 24fps) (Dolby)
1920 x 1080 pixels, 30p (FHD: 24Mbps / AVCHD) (Sensor Output is 30fps) (Dolby)
1920 x 1080 pixels, 60i (FHD: 17Mbps / AVCHD) (Sensor Output is 60fps) (Dolby)
[/TD]
[/TD]
[/TD]
[/TD]
[/TD]
[TD="bgcolor: #C0C0C0"] 1920 x 1080 pixels, 60p (FHD: 28Mbps / MP4) (Sensor Output is 60fps) (AAC)
1920 x 1080 pixels, 30p (FHD: 20Mbps / MP4) (Sensor Output is 30fps) (AAC)
1280 x 720 pixels, 30p (HD: 10Mbps / MP4) (Sensor Output is 30fps) (AAC)
[/TD]
[/TD]
[/TD]
[/TD]
[TD="bgcolor: #C0C0C0"] STD
Video
[/TD]
[TD="bgcolor: #C0C0C0"] 640 x 480, 30p (VGA: 4Mbps / MP4) (Sensor Output is 30fps) (AAC) [/TD]
[/TD]
[/TD]
[/TD]
[TD="bgcolor: #C0C0C0"] High Speed Video [/TD]
[TD="bgcolor: #C0C0C0"] 1920 x 1080 pixels, 30p (FHD: MP4) (Sensor Output is 120fps)
1280 x 720 pixels, 30p (HD: MP4) (Sensor Output is 240fps)
640 x 480 pixels, 30p (VGA: MP4) (Sensor Output is 360fps)
[/TD]
[/TD]
[TD="bgcolor: #808080"] Continuous Recordable Time (Motion Pictures) [/TD]
[TD="bgcolor: #FFFFFF"] AVCHD [/TD]
[/TD]
[TD="bgcolor: #FFFFFF"] Approx. 130 min (FHD/60p), Approx. 135 min (FHD/60i) [/TD]
[/TD]
[/TD]
[TD="bgcolor: #FFFFFF"] MP4 [/TD]
[/TD]
[TD="bgcolor: #FFFFFF"] Approx. 130 min (FHD) [/TD]
[/TD]
[TD="bgcolor: #808080"] Actual Recordable Time (Motion Pictures) [/TD]
[/TD]
[TD="bgcolor: #FFFFFF"] Approx. 65 min (FHD/60p), Approx. 70 min (FHD/60i) [/TD]
[/TD]
[/TD]
[/TD]
[TD="bgcolor: #FFFFFF"] Approx. 65 min (FHD) [/TD]
[/TD]
[TD="bgcolor: #808080"] Exposure Parameters [/TD]
[TD="bgcolor: #C0C0C0"] Exposure [/TD]
[/TD]
[TD="bgcolor: #C0C0C0"] Program AE, Aperture Priority AE, Shutter Priority AE, Manual [/TD]
[/TD]
[/TD]
[TD="bgcolor: #FFFFFF"] Exposure Compensation [/TD]
[/TD]
[TD="bgcolor: #FFFFFF"] 1/3 EV step, +/-5 EV (+/-3 EV for motion picture) [/TD]
[/TD]
[/TD]
[TD="bgcolor: #C0C0C0"] Auto (AE) Bracketing [/TD]
[/TD]
[TD="bgcolor: #C0C0C0"] 3, 5, 7 frames in 1/3, 2/3 or 1 EV Step, Max. +/-3 EV [/TD]
[/TD]
[/TD]
[TD="bgcolor: #FFFFFF"] Light Metering [/TD]
[/TD]
[TD="bgcolor: #FFFFFF"] Intelligent Multiple / Center Weighted / Spot [/TD]
[/TD]
[/TD]
[TD="bgcolor: #C0C0C0"] ISO Sensitivity [/TD]
[/TD]
[TD="bgcolor: #C0C0C0"] Auto / i.ISO / 80* / 100* / 125 / 200 / 400 / 800 / 1600 / 3200/ 6400 / 12800 / 25600* (* Extended ISO)
(Changeable to 1/3 EV step)
[/TD]
[/TD]
[TD="bgcolor: #808080"] Picture Quality [/TD]
[TD="bgcolor: #FFFFFF"] Still Picture Recording [/TD]
[TD="bgcolor: #FFFFFF"] 4:3 [/TD]
[TD="bgcolor: #FFFFFF"] 4864x3648 (17.5M) (L) / 3456x2592 (9M) (M) / 2432x1824 (4.5M) (S) [/TD]
[/TD]
[/TD]
[TD="bgcolor: #FFFFFF"] 3:2 [/TD]
[TD="bgcolor: #FFFFFF"] 5472x3648 (20M) (L) / 3888x2592 (10M) (M) / 2736x1824 (5M) (S) [/TD]
[/TD]
[/TD]
[TD="bgcolor: #FFFFFF"] 16:9 [/TD]
[TD="bgcolor: #FFFFFF"] 5472x3080 (17M) (L) / 3840x2160 (8M) (M) / 1920x1080 (2M) (S) [/TD]
[/TD]
[/TD]
[TD="bgcolor: #FFFFFF"] 1:1 [/TD]
[TD="bgcolor: #FFFFFF"] 3648x3648 (13.5M) (L) / 2592x2592 (6.5M) (M) / 1824x1824 (3.5M) (S) [/TD]
[/TD]
[/TD]
[TD="bgcolor: #C0C0C0"] Image Quality [/TD]
[/TD]
[TD="bgcolor: #C0C0C0"] RAW / RAW+Fine / RAW+Standard / Fine / Standard [/TD]
[/TD]
[/TD]
[TD="bgcolor: #FFFFFF"] White Balance [/TD]
[/TD]
[TD="bgcolor: #FFFFFF"] Auto / Daylight / Cloudy / Shade / Incandescent / Flash / White Set1 / White Set2 / White Set3 / White Set4 / Color Temperature
(2-axis Adjustable)
[/TD]
[/TD]
[/TD]
[TD="bgcolor: #C0C0C0"] Photo Style [/TD]
[/TD]
[TD="bgcolor: #C0C0C0"] Standard, Vivid, Natural, Monochrome, Scenery, Portrait, Custom, Cinelike D*, Cinelike V* * When Creative Video mode is selected. [/TD]
[/TD]
[/TD]
[TD="bgcolor: #FFFFFF"] Color Mode / Color Effect [/TD]
[/TD]
[TD="bgcolor: #FFFFFF"] - [/TD]
[/TD]
[/TD]
[TD="bgcolor: #C0C0C0"] Picture Adjustment [/TD]
[/TD]
[TD="bgcolor: #C0C0C0"] Contrast, Sharpness, Noise Reduction, Saturation*, Filter Effect**
* Except for Monochrome mode. ** For Monochrome mode only.
[/TD]
[/TD]
[/TD]
[TD="bgcolor: #FFFFFF"] Aspect Bracketing [/TD]
[/TD]
[/TD]
[TD="bgcolor: #808080"] Other [/TD]
[TD="bgcolor: #969696"] Digital Red Eye Correction (Red-Eye Removal) [/TD]
[/TD]
[TD="bgcolor: #969696"] Yes (On / Off) [/TD]
[/TD]
[/TD]
[TD="bgcolor: #FFFFFF"] GPS [/TD]
[/TD]
[/TD]
[/TD]
[TD="bgcolor: #C0C0C0"] Wi-Fi [/TD]
[/TD]
[TD="bgcolor: #C0C0C0"] IEEE 802.11b/g/n
2412 MHz - 2462 MHz (1-11 ch)
WPA / WPA2
Infrastracture Mode / WPS / Wi-Fi Direct
Wi-Fi Button
[/TD]
[/TD]
[/TD]
[TD="bgcolor: #FFFFFF"] NFC [/TD]
[/TD]
[TD="bgcolor: #FFFFFF"] ISO/IEC 18092, NFC-F (Passive Mode) [/TD]
[/TD]
[/TD]
[TD="bgcolor: #C0C0C0"] Zoom in Motion Picture [/TD]
[/TD]
[TD="bgcolor: #C0C0C0"] Yes [/TD]
[/TD]
[/TD]
[TD="bgcolor: #FFFFFF"] Self Timer [/TD]
[/TD]
[TD="bgcolor: #FFFFFF"] 2 sec / 10 sec / 10 sec (3 images) [/TD]
[/TD]
[/TD]
[TD="bgcolor: #C0C0C0"] Self Shot Mode [/TD]
[/TD]
[TD="bgcolor: #808080"] Playback [/TD]
[TD="bgcolor: #808080"] Display [/TD]
[/TD]
[TD="bgcolor: #FFFFFF"] All, Slideshow, Filtering Play (Picture Only, Video Only, Category Selection, Select Date, Favorite), Calendar [/TD]
[/TD]
[/TD]
[TD="bgcolor: #969696"] Thumbnails / Zoomed Playback  [/TD]
[/TD]
[TD="bgcolor: #969696"] 12,30-thumbnails / Yes [/TD]
[/TD]
[/TD]
[TD="bgcolor: #FFFFFF"] Calendar Display / Dual-Image Playback [/TD]
[/TD]
[TD="bgcolor: #FFFFFF"] Yes / No [/TD]
[/TD]
[/TD]
[TD="bgcolor: #969696"] Set Favorites / Rotate Image [/TD]
[/TD]
[TD="bgcolor: #969696"] Yes / Yes [/TD]
[/TD]
[/TD]
[TD="bgcolor: #FFFFFF"] Show Histogram [/TD]
[/TD]
[TD="bgcolor: #FFFFFF"] Yes [/TD]
[/TD]
[/TD]
[TD="bgcolor: #969696"] Show Highlights [/TD]
[/TD]
[TD="bgcolor: #969696"] Yes [/TD]
[/TD]
[/TD]
[TD="bgcolor: #FFFFFF"] DPOF Print Setting / Set Protection [/TD]
[/TD]
[TD="bgcolor: #FFFFFF"] Yes / Yes [/TD]
[/TD]
[TD="bgcolor: #808080"] Edit [/TD]
[TD="bgcolor: #969696"] Retouch [/TD]
[/TD]
[TD="bgcolor: #969696"] No [/TD]
[/TD]
[/TD]
[TD="bgcolor: #FFFFFF"] RAW Processing [/TD]
[/TD]
[/TD]
[/TD]
[TD="bgcolor: #969696"] Resize / Cropping / Aspect Conv. / Leveling [/TD]
[/TD]
[TD="bgcolor: #969696"] Yes / Yes / No / No [/TD]
[/TD]
[/TD]
[TD="bgcolor: #FFFFFF"] Copy / Title Edit / Text Stamp [/TD]
[/TD]
[TD="bgcolor: #FFFFFF"] No / Yes / Yes [/TD]
[/TD]
[/TD]
[TD="bgcolor: #969696"] Cut Animation [/TD]
[/TD]
[/TD]
[/TD]
[TD="bgcolor: #FFFFFF"] Video Divide [/TD]
[/TD]
[/TD]
[/TD]
[TD="bgcolor: #969696"] PictBridge Support [/TD]
[/TD]
[TD="bgcolor: #969696"] Single / Multi / All / DPOF / Favorites [/TD]
[TD="bgcolor: #808080"] Setup [/TD]
[/TD]
[TD="bgcolor: #FFFFFF"] OSD Language [/TD]
[/TD]
[TD="bgcolor: #FFFFFF"] Please refer to "OSD" Sheet [/TD]
[TD="bgcolor: #808080"] Others [/TD]
[TD="bgcolor: #808080"] Monitor [/TD]
[TD="bgcolor: #969696"] LCD Monitor [/TD]
[/TD]
[TD="bgcolor: #969696"] 3.0" (7.5cm) Free-Angle TFT Screen LCD Display (921K dots), AR Coating
Field of View: Approx. 100%, Wide Viewing-angle
Power Monitor mode, AUTO Power Monitor mode
[/TD]
[/TD]
[TD="bgcolor: #808080"] Flash [/TD]
[TD="bgcolor: #FFFFFF"] Built- in- Flash [/TD]
[/TD]
[TD="bgcolor: #FFFFFF"] Auto*, Auto/Red-eye Reduction*, Forced On, Forced On/Red-eye Reduction, Slow Sync., Slow Sync./Red-eye Reduction, Forced Off * For iA, iA+ mode only.
Flash Synchro: 1st / 2nd Slow Sync.
Synchronization for flash dimming and exposure compensation
0.3 - 13.5m (Wide / ISO Auto), 1.0 - 9.5m (Tele / ISO Auto)
[/TD]
[/TD]
[TD="bgcolor: #808080"] Media [/TD]
[TD="bgcolor: #969696"] Recording Media [/TD]
[/TD]
[TD="bgcolor: #969696"] SD Memory Card, SDHC Memory Card, SDXC Memory Card (Compatible with UHS-I standard) [/TD]
[/TD]
[/TD]
[TD="bgcolor: #FFFFFF"] Built- in- Memory [/TD]
[/TD]
[/TD]
[TD="bgcolor: #808080"] Audio [/TD]
[TD="bgcolor: #969696"] Microphone / Speaker [/TD]
[/TD]
[TD="bgcolor: #969696"] Stereo / Mono [/TD]
[/TD]
[TD="bgcolor: #808080"] Interface [/TD]
[TD="bgcolor: #FFFFFF"] Interface [/TD]
[/TD]
[TD="bgcolor: #FFFFFF"] microHDMI, AV Output (NTSC), USB (AV/USB Multi) [/TD]
[/TD]
[/TD]
[TD="bgcolor: #969696"] Remote Input [/TD]
[/TD]
[TD="bgcolor: #969696"] φ2.5mm for Remote [/TD]
[/TD]
[/TD]
[TD="bgcolor: #FFFFFF"] External Microphone Input [/TD]
[/TD]
[TD="bgcolor: #FFFFFF"] φ3.5mm for External Microphone [/TD]
[/TD]
[TD="bgcolor: #808080"] Power [/TD]
[TD="bgcolor: #969696"] Power [/TD]
[/TD]
[TD="bgcolor: #969696"] Li-ion Battery Pack (7.2V, 1200mAh, 8.7 Wh) (Included)
AC Adaptor (Input: 110 - 240V AC) (Included)
[/TD]
[/TD]
[/TD]
[/TD]
[TD="bgcolor: #808080"] Standard Package [/TD]
[TD="bgcolor: #969696"] Included Software [/TD]
[/TD]
[TD="bgcolor: #969696"] PHOTOfunSTUDIO 9.5PE
SILKYPIX Developer Studio
LoiLoScope (trial version)
Adobe Reader
[/TD]
[/TD]
[/TD]
