Hello,
Doing a lot work with DSLR's (the 5DMII and GH2) and occasionally not working with a sound guy.
Looking to upgrade some equipment and have already moved on from my Rode microphone to a Sennheiser MKH-60 (though I always keep an extra Oktava hypercardoid for indoors).
The thing to know today is that the 5D no longer needs an AGC disable tone, as Canon now allow us to manually turn it off. However, apparently with the Canon firmware, even though the digital gain is no longer an issue, the analog gain is fixed at +31db. The only way to go is with the Magic Lantern hack to control both. The other advantage with ML correspondingly is onscreen levels.
Given that I am mostly working in ML therefore, the crummy level indicators on the Juicedlink are not an issue. It is smaller, lighter and the pre-amps are apparently pretty good. The unit still retains an AGC disable function and can be used on DSLR's which still have that issue like the 7D. It can also be found for as low as $300.
The Sound Devices Mixpre-D appears much more solid and heavier, has a far better levels indicator as well a tone generator, and a host of little advantages like USB connectivity. It does not have an AGC disabler. I do not know about the quality of it's pre-amp, but I am sure it is probably pretty good. It is also about $750.
My question is if anyone has had experience with BOTH of these units and how they compared for work with DSLR's. Beyond that of course your +'s and -'s are very welcome indeed, just no "you get what you pay for" comments please!
Thanks in advance for your input.
