Paul Hudson
Vacuum Tube Member
The Neutrik connector are used often in audio high output sound gear (amps and speakers). Places like Guitar Center probably carries long cables in stock.
It's a big G38 single-ended HMI bulb. Looks like this one...I'm also very interested in seeing pics of the bulb and any info printed on it.
It's a real HMI 1.2k. Tungsten equivalent would be a 5K, but that's not even a fair comparison because that 5K tungsten would be putting out orange light, and to get it blue you'd have to gel it with CTB, which means, really, you'd need a 10K to 20K tungsten fixture to match the amount of blue light this thing outputs. It's a light cannon. Indoors I needed ND3 and F4 and 200 ISO to be able to white-balance off of a white card, at 12 feet. And that was flooded out, not spotted. Is that insane or what? I mean, a 1.2k isn't that big in the world of HMI's, but in terms of something with the sensitivity of an AF100 it's like having a 6K HMI.Did they give any indication whether the 1.2k output was in tungsten equivalent or actual HID output? It says 1.2k HMI on the ebay thing but who knows..
Alas, only Speakon. I found a Powercon cable in stock at Markertek, but that's a few days' shipping, and I'm not entirely certain that the cabling would be wired the same. I assume it must be (I mean, what's the point of making a knockoff cable connector if the cable itself isn't compatible??)The Neutrik connector are used often in audio high output sound gear (amps and speakers). Places like Guitar Center probably carries long cables in stock.
It was only on for 10 minutes or so, so yeah, maybe there's something about the bulb that would burn off over time? I just chalked it up to maybe the lens, and it's just yet another part of profiling your equipment to find what works and what to avoid...Yeah, in my experiments I've seen the green halo around some HID light before. Not sure what causes it other than some kind of prismatic effect from the fresnel. It also seems to be related to how well the doping chemicals evaporate inside the pressure chamber in the bulb and the different colored areas of light can move around.
Jury's still out... I had a 1200w magnetic-ballast Sirio or DeSisti that I bought off ebay for about the same price... much heavier ballast, but quieter, and it just worked, but it died on me before the CMOS revolution came about and made magnetic-ballast HMIs less attractive. If this unit was magnetic, I'd have little hope for it, but because it's electronic and therefore doesn't cause the scrolling waves and bands in the footage, I have some optimism. It all depends on the power cord and whether I can get the ballast far enough away to make it actually usable.sounds like a deal so far though.
On that unit, what they've done is bolt the ignitor to the side and the cord is hard wired coming out of there. You can verify it by opening up that black box on the side and seeing if there is another black box in there with 4 fairly hefty wires coming out of it. 2 are input and 2 are output. Probably different colors on each side. No polarity so its not necessary to know which side is which on input or output but of course don't mix up input and output though.
You may indeed be able to make a longer cable and put it in there yourself if the ignitor is there in the side box.
This was our 1200w cold start beta unit and a couple were bought by a dvxuser and he's mentioned them before on here. Its been about 2 years now and still running last I heard:
About the same price. Should be using the same bulb. The longer base at the bottom is the good place to put an ignitor and we put a quick lock military connector on the outside of fresnel to be able to have a longer cord if necessary. Yoke is a professional type with our yoke clamp and the stand adapter is a junior male type.
He thought the fan on that unit was too loud but not even close to what we are talking about on this other unit in question.
I just didn't think it was worth going ahead with all these "fan" projects because I already knew what the reaction was going to be. Not worth it.
The ballast is prohibitively noisy, but with the cheap extension cable you can put it in a different room, shut the door, and not even worry about it...
Barry have you used these lights on a production yet.
For the price, I'd be willing to pick one up for use where audio capture isn't a need.
No, it's sitting on the shelf. Haven't done anything that calls for it yet.
