GaryOldman
The camera is awesome...
You need to have Parkingson to be bothered by the jello.
Seriously if you are a camera operator with basic skills, the images you can get with the camera are going to blow you away on your 42" plasma
Sorry but the flashing effects on a global shutter are highly over rated. THe effect is simply different to what you are after, not worse than you are used too.
Global shutter blows out the whole frame, Rolling Shutter blow out part of the frame. Since when is a complete blow out of a frame acceptable quality footage?
No camera handels flash/strobe exposures properly. I have never had a client even mention the different result from an EX1 to me and I shoots weddings with flash's going off everywhere. At least you still get to see a significant portion of the frame when with global shutter the whole frame is obliterated.
PS: I have never seen any 'jellocam' either. The D90 has jellocam, the EX series has a slight un-noticable skew on certain fast pans which you won't ever notice unless you do a freeze frame to examine a single frame.
On vimeo I saw a clip from the EX3 where the shooter panned across a picket fence, and the wobble was horrific. But then, he was specifically looking to point out flaws. And was perhaps misusing the camera. I don't know. I'm praying this beautiful piece of equipment will suit me fine with zooms and pans and hand held work. Thanks!
What it really boils down to is what matters most to you. That's the most important question. Do the pros of the camera outweigh the cons?
Months ago Phillip Bloom's EX videos convinced me to pursue XDCAM. Then all the hoopla about jello vision and rolling shutter artifacts came out and I was unsure again.
I'm convinced for good now, though.
Getting my EX1 with three 16gb SxS cards next week from B&H, and will start alerting clients to my impending HD abilities. Thanks to everyone that replied, particularly admar316. You guys rock.
