Hello,
for me, when I film large landscape with my FX6, set in UHD, I have a lot of aliasing and moire...It's too sharp.. (with detail off, of course) This is a big problem !
It seems there isn't a low pass filter.
In HD 1920 1080, there is no problem...
Except that, to answer the first question, with faces, the sharpness is good fot me, (with detail off) , better than the C300mk2... So, in UHD, the sharpness is too hard for me, and that's probably why I notice a lot of aliasing and moiré with wide shots !
""Thicker" is one of the terms that has been used over the years to ambiguously mean better-looking without being able to explain why."
Over a decade ago I started shooting and editing raw photos. The first time I opened a raw file and played around with it was a revelation. It looked amazing! And suddenly I could make major colour and exposure adjustments with everything still looking 'right'. After half an hour I realised that I wasn't in raw mode. I'd been playing around with a jpeg.
Plus you'd need two of each camera . . .
Both using a 50 year-old lens. Both were absolutely pin-sharp and I would not give questions over the camera's sharpness another thought.
I'll bet you can't name any serious camera shootout that ever used two models of the same camera.
Of course not. It was an observation on how if you are going to be anal to the nth degree about a controlled experiment you need to see if there is variance between any two of the same model before checking it against another model. There is no end to the rabbit hole one can go down.
Yeah, you're right, why eliminate some really simple variables when doing testing? If you want to be an ass, go ahead.
Exactly which of these variables do you think can be ignored and still produce a valid comparison between cameras?
1) Lens
2) Codec
3) Framing/shot
4) S-LOG3
5) Exposure
6) White balance
