Duh!
Usernames don't exempt people from being required to follow rules of simple good manners.Well, his name is Cranky...
Identical, yes.As in - Will 1 minute of 720P60 footage in DVCPRO HD as filmed by HVX take the roughly the same amount of GB as 1 minute of 720P30 footage? Especially if captured by something like OnLocation?
So, recording 720/30pN onto a card and then dumping it on a computer will yield a higher-quality video than streaming 720p30 via FireWire?The frames are actually duplicated. An intraframe codec means that every frame exists, in its entirety, individually, hence no frame duplication flags. 30pN doesn't travel down the firewire, so OnLocation won't see an HVX/HPX in 30pN mode.
It will result in an identical-quality video stream, but in half the space.So, recording 720/30pN onto a card and then dumping it on a computer will yield a higher-quality video than streaming 720p30 via FireWire?
Intraframe means that every frame is compressed individually and stands alone. By using frame-repeat flags, it's no longer intraframe, because inherently the duplicate frame is dependent on the prior frame.I am not sure that "an intraframe codec means ... no frame duplication flags." It means no "delta" frames, but why not repeating a whole frame? I googled a bit, did not find anything definitive.
I got this, but is it 100/50 Mbit/s or 80/40 Mbit/s for 50/25 fps, considering that 60 fps is 100 Mbit/s. Ok, I just took a look at the HPX500 info, and it seems that 50/60fps and 25/30fps use the same bitrate, 100 and 50 Mbit/s respectively. Well, duh (may I "duh" myself?), considering that DVCPROHD is a variant of DV, which uses the same bitrate for 50/60 Hz versions.The actual bitrate used is dependent on the frame rate, because each and every frame is allocated the exact same amount of bandwidth.
