Too expensive as I will keep the 550d just for my short and probably upgrade to GH2 or a successor. Is there no railsystem?
The redrock DSLR cinema rig has enough room to switch the battery and the memory card without removing the camera.
Let's see if I understand you correctly, muroshi. I have my T2i usually with the Manfrotto 501PL sliding quick release plate mounted, so that I can quickly take it away from the tripod and remount it, for instance, on my Kameraslider or on my Hague DSLR cage or on the Steadycam Jr. for different shots, or else just use it handheld.
In any case, I can insert a new battery whenever I need, because the mounting of the 501PL does not interphere at all with the battery box in my T2i, as you can see in the picture.
/Users/anazano/Desktop/plate and battery opening.jpg
I hope this is helpful to you, if I interpreted accordingly your question, murochi.
Best,
Ana.
The battery grip is a good answer - until you get on rails, or use a follow focus or a matte box. I find they just make a bad video form factor even worse.
If you move to a rails setup: I was able to chop a corner off my DSLR riser to make room for the battery door to open and close. An angle grinder & a file are handy to have around.
Jag35 had an adapter for some Canon cameras that allowed you to use an external battery pack, might check into that as well.
