KyleProhaska
What is your opinion of the 70-200 F2.8 IS II for event shooting with the C100? I shot an event friday night with the 24-105 F4 and it worked well but I am in the market for a 70-200. Undecided between the F4 IS (much lighter in weight and on wallet) or the F2.8 IS. I'm leaning towards the F4 as it would be easier for handheld/monopod and the C100 should be able to handle the lower light, or do you think the F2.8 is significantly better?
Well the bigger difference is likely between the F2.8 I IS and F2.8 II IS where the glass is of a little higher quality. You can see comparisons online that are telling. If I was going to get a lens of this size/quality I wanted the best I could get my hands on. It's doubtful you'll use F2.8 much, because of the obvious focus difficulties so you gotta wonder if the lenses speed matters a ton for what you're doing. The C100 can handle the ISO's on the high end well enough for you to stop down a little anyways.
I think it just comes down to whether or not you want a great lens or a really great lens and whether or not you need a faster one in some situations. Doesn't sound like you do, otherwise you'd know your answer already. Go for the 70-200 F4 I guess?
