Ebrahim Saadawi
Carbonite Member
The good:
-The hedious aliasing/moire are finally almost gone, it's on d5300/7dii/5diii level at that area
-Lowlight performance is about a stop above last gen. similar to 7Dii. Interestingly this only applies to video not raw stills so better processing is the reason not cleaner sensor.
-Overall video quality is identical to 5Diii and 7Dii, i.e., clean of artefacts but quite soft compared to the 4k competetion.
-T6s HDR mode works brilliantly, much better than expected. It gives a really high DR at 720p resolution (which is not a big hit from 1080p as both are softish anyway)
-Lossless 3x crop mode is back as in the t3i, giving a clean almost s16 crop mode.
-Hybrid AF III (or whatever they call it) is almost identical to Dual Pixel AF in video AF. So it's very organic in motion, locks accurately and works better than any other system on the market. Really good video AF here.
The bad:
-Again, quite soft. Think 5D/7D
-No 1080p at 60p, and the 60p 720p shows aliasing, so not a great slomotion camera for a professional (fine for casual use)
-No headphone jack
-No peaking/zebras (while strangely both implemented in the new mirrorless Eos M3)
-No clean HDMI output or Timecode lile on 7D mk II
Conclusion: The T6s body is overally a joy to use as a stills/video hybrid, much more sophisticated than all entry level cameras and previous rebels, and the video performance now matches the Nikon counterparts, just not really great for hardcore purist video shooters like us, so move along, get an nx1 or something. This is a great camera for someone discovering photography/videography giving pro results with a cheap lens selection, it's really a lovely body especially with the 10-18mm IS + 18-135mm STM, 50mm 1.8 + 55-250mm IS STM and and those cheap high performers.
In brief, recommend it to your 15 year old niece bitten by the photography/videography bug, she can do anything with it, but for yourself as a pro video shooter, get an nx1 or GH4 or A7s or something and tinker with manual vintage/cine glass and adapters. Better for you overally especially in how sharp your end result will look. You can't afford to deliver soft video now when every one else is sharp/HD, bad for your image/business.
The bad:
-No headphone jack
