Macfionn
Impact VW-VBG260EX Extender Battery
Purchased on B&H for $9.95 plus shipping.
Item is now showing as discontinued on B&H.
Perhaps can be found elsewhere.
I took pics and enclosed below, if interested.
Having ordered this on a suggestion from Robert M. Wright, I'm rather happy I did. It literally 'piggy backs' onto the existing Panny VW-VBG260, thus fooling the camera into thinking a Panny battery is attached. It is NOT a stand-alone battery, nor can be used as such with the HMC40.
I found that it adds an additional 2.5 hours of recording time, and takes every bit as much time to charge as the VW-VBG260 itself.
I drained it thoroughly, and recharged it again, with same 2.5 hours of record time.
*note* I haven't had it long enough to see how long I can use it before it begins to deteriorate.
I was worried it would but too much stress on the cameras battery pins, but it fits pretty snug into the battery guide, relieving that worry.
The amount of time reflected by the camera until battery discharge is that of the Impact extender itself! You don't get a 'combined' battery usage time. Once the Impact extender is run down, you then remove the Panny battery and plug "it" into the camera to use while recharging the Impact extender.
Details:
The Impact VW-VBG260EX Extender Battery prolongs the life of your Panasonic camcorder's VW-VBG260 lithium-ion battery. Simply mount the camcorder's original battery on the back of the VW-VBG260EX Extender Battery. It is mounted onto the extender battery only for the use of the chip information (no power will be drained), allowing the extender battery to function with the camcorder.
This extender battery is compatible with the following Panasonic camcorders that use the VW-VBG260 lithium-ion battery: HDC-SD9, HDC-HS9, HDC-SD5, HDC-SD1, HDC-SX5, HDC-DX1, SDR-H60, SDR-H40/41, SDR-H200, SDR-H18, VDR-D310, VDR-D50/51, VDR-D230, VDR-D220, VDR-D210, PV-GS500, PV-GS320, PV-GS85, PV-GS83, PV-GS90, PV-GS80.
Compatibility This extender battery is compatible with the following Panasonic camcorders that use the VW-VBG260 lithium-ion battery: HDC-SD9, HDC-HS9, HDC-SD5, HDC-SD1, HDC-SX5, HDC-DX1, SDR-H60, SDR-H40/41, SDR-H200, SDR-H18, VDR-D310, VDR-D50/51, VDR-D230, VDR-D220, VDR-D210, PV-GS500, PV-GS320, PV-GS85, PV-GS83, PV-GS90, PV-GS80
Specs:
Chemistry - Lithium-ion
Capacity - 2000mAh
Output Voltage - 7.4V
Dimensions - 1.8 x 1.5 x 1.8" (46.5 x 38 x 45.5mm)
Details:
Specs:
Capacity - 2000mAh
