any news on this? I need a timeframe to see if I should go for the CineVate now or wait this out.
thanks.
If they are like $400 and coming out in late January I don't know if I can wait. Thanks.
I have a question for the Letus folk.
The support raiser that came with the letus extreme has been extremely handy when mounting on rails to sling from underneath, the adapter. Unfortunately, it tends to slide down and down, until it gets to the point where its not actually supporting the weight anymore, so i have to always check to see if the screw has slipped down slightly. Any way to fix this?
I thought PaPa was saying the vertical support screw was the one slipping on him. If you can't get it to tighten to the CF rods of the IndiRails then that is a different issue. CF has a tendency to vary in diameter. If you can't tighten it down enough, your rods are probably a hair under 15mm.
