Beat Takeshi
Two-Hip Shakur
It would be cool if you could point it at a scene and it takes the image and flattens it out to solid shapes depending on exposer with a number corrosponding to the stop number. I dont know if i explained that clear though. Like it takes the image and turns it black and white and then posterizes to blocks of exposure. Sort of like a zebra but for the full range. This way you dont have to go over with a meter to read if your shadows are too dark or your highlights are too bright at the same time. As you adjust your lights you can see the chart change in realtime. You can even set a preferred exposure and it will mark off the spots in the image that fall out of the range.
