BMFM FILMS
That's the exposure compensation, there's been lots of discussion about it. The other way is holding the play button and the up arrow to make it brighter. But thats about it.
i wonder if there is a way to dim that light
I like using the light because it's the same amount of light every time. It makes it easy to recreate what I did.
I set the f-stop at f8 then put camera in LV mode. Turn light on and I put it about 10 inches from lens. You will see the camera adjust down then I lock exposure. I opened up the f-stop and started shooting. That's it.
f8 is too much, pumps the gain too high, i put it at f4 and it's fantastic. i'm gonna check to see if i can put a higher watt bulb in it and play with the +/- values and maybe we can finally get accurate shutter speeds and achieve low light.
there is a led light at wal-mart for 7bux that you can dim 3 ways.
i'm gonna check into that tomorrow...
