bruceallen
Not a derailment at all, seeing as this thread has the word Dynamic in the title
Really any proper test of i.Dynamic vs Highlights / Shadows vs Contrast settings needs to have a Stouffer test in it anyway!
RE: lighting: yes, as diffuse and even a backlight as possible is ideal. Eg a lightbox style setup.
Also if you put the wedge so that the brightest part is not centered but nearer a diagonal corner, that'll help test accuracy as then lens flares will likely go to the other diagonal rather contaminate the wedge. Reference here (Art Adams' excellent Arri dynamic range article):
http://provideocoalition.com/aadams/story/alexa_dynamic_range_its_all_in_how_you_use_it/P2
However all of that is academic: eg if you want to compare with other Stouffer tests and want to keep all variables constant.
If you're just testing different settings on the same camera (eg "this setting has 1 more stop than that setting" vs "this camera has 9.38 stops of DR"), you can do whatever you like!
Also, cameras can have different DR at different white balance settings and with different lighting conditions (because the R, G, B filters may mean different channels are noisier than others and also clip at different points). So you may get a different result if you use a tungsten bulb vs a fluorescent bulb or a Kinoflo or an HMI or whatever.
If you don't have a waveform monitor, I think the simplest way would be to set 100% zebras and then expose so it looked like all detail was being completely clipped out of the top couple steps (eg you want at least 3 steps to be totally clipped). Then you just count from when it is clipped to where you can't see anything.
Bruce Allen
www.boacinema.com
Bruce Allen
www.boacinema.com
